Oil Screen Cover Removal GL1000
- Zinc Member
I'm looking through the manual and part of the maintenance is cleaning the oil screen cover. Than manual says
Remove 4 screws securing oil screen cover. Remove the engine mounting nut. Flex frame outward with large drift or pry bar just enough to remove screen. Clean screen thoroughly with solvent.
I had a quick look last week at the screen cover and it seems like those Phillips (JIS) screws are almost impossible to reach. Is that the case or is there a technique? Also, flexing the frame outward with a pry bar seems strange. The exhaust is off as I'm putting a better shape OEM one I found.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
Re: Oil Screen Cover Removal GL1000
Getting those screws out of the first opstacle. The front screw won’t come all the way out with flexing the frame outward some. When reinstalling it I use hex bolts instead of screws and put a shorter one in the front hole. No more flexing.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
I use a plastic chain saw wedge (used to prevent pinching the blade on the saw in a kerf) to hold the out after prying with a well-padded crowbar. But first, make sure you loosen all of the bolts that keep it pinched!
- flyin900
From distant memory on that one you need to remove the front and rear engine bolts if I recall, as it allows more flex in the frame than just the front bolt. A wedge of your choice will give you the room needed and then replace with hex head bolts as noted.MikeNTexas wrote: ↑Sun Nov 07, 2021 8:47 pm The front screw won’t come all the way out with flexing the frame outward some. When reinstalling it I use hex bolts instead of screws and put a shorter one in the front hole. No more flexing.
If you change your oil/filter regularly and keep a close look at the old oil for particles when you do a change, it will likely be a one time job. Unless the clutch fibers are coming apart, you will find the screen is pretty clean in most cases.
I have done it once in frame and a number of times when doing a re and re on engines. I have never found any serious junk in there just a few bits. It likely depends on how the PO's did oil changes and maintenance.
Current Bikes:
- Zinc Member
It's really strange that to remove it would require a pry bar to the frame. It's unlike Honda engineering to require such a technique but I doubt it was an oversight on their part.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- flyin900
Somebody got a pink slip on that one for sure. It’s a workaround after the fact.
Would have made sense to put the removable frame section on that side to facilitate easier access to both the neutral switch and oil screen.
Current Bikes:
- Lucien Harpress
It's one of the little quirks of the GL1000 (along with the neutral light) that shows Honda didn't quite have everything figured out yet. I can only guess those items ended up where they did due to the configuration of the engine, and when they found the frame rails landed where they did, deemed them low maintenance enough to not be worth a redesign.
Similar to the valve cover on the SOHC 750s. You need to remove the engine if you want to take the cover off, but the average owner has no reason to do so, so Honda left it.
Of course, Honda probably didn't figure people would be riding these things 40 years later.
I doubt if the screen was ever cleaned on most of these bikes, and I only did my 78 (over 140K miles) because the engine was out... the only thing that really would gunk them up is a disintegrating clutch or blue RTV, or not regular oil changes
- Zinc Member
I might just leave it alone then. The Honda manual mentions flexing the frame 2mm.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- tlbranth
You ain't seen nothing yet. One of the water pump cover screws is also behind the frame. Static timing on 1 & 2 is a 10 minute job. Static timing on 3 & 4 takes 3 or 4 weeks if you don't slack off. Dynamic timing requires that you have a special window and a removable eyeball that you can position over the window to try and spot the timing marks which you won't be able to see anyway. Carbs will become a career. There's more. Much more. You can read all about it in the book of Revelation.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
PERFECT!
Cliff (74yrs )
- Lucien Harpress
I would laugh except you're not wrong.
- BlueThunder
That's what happens when car guys design a motorcycle motor!
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
I think it would have been better for the sidestand to be attached to the non-removable side of the frame too.
Rodger: RTV = Room Temperature Vulcanizing and can refer to any number of rubberlike materials that don't require heat to cure. I assume that you are probably referring to silicone sealant; Why do you think that blue silicone sealant is more likely to cause problems than any other colour?
Re setting the timing: IIRC, it always took me more time to go and get new points than it did to install and adjust them. The hardest part of installing the new ones was always running the wire and setting the points took perhaps 10 minutes for the ones fixed to the plate and 15 minutes for the adjustable ones. Of course, that assumes that you replaced the condensers at the same time because bad condensers can make as much difference as mis-adjusted points.
FWIW, it should take about as long to set the timing on a Dyna S as it does to set the timing on points and I believe that took me less than 20 minutes when I moved my Dyna to my "new" engine.
These problems aren't from "car guys" designing the engine but from not enough communication between the team designing the engine and the team designing the frame and are pretty common in a lot of models from a number of manufacturers.
What's nest, someone complaining that you have to remove the engine to replace the alternator stator?
- Lucien Harpress
They finally figured THAT one out by the time the Valkyrie rolled around. (And perhaps the GL1500. I have no clue about the frame geometry on that one.)Sidecar Bob wrote: ↑Thu Nov 11, 2021 11:49 am What's nest, someone complaining that you have to remove the engine to replace the alternator stator?
- 15 Replies
- 522 Views
Last post by rich3389
- 8 Replies
- 320 Views
Last post by tory
- 31 Replies
- 1951 Views
Last post by redglbx
- 1 Replies
- 2223 Views
Last post by steelhorseangel
