Frame number GL1 vs GL2
resenok
Lead Member
Lead Member
Post by resenok »
After buying the GL1000, I asked why the frame number starts with GL2 and what the year of production could be. The first registration in Germany was in 1981. So many unanswered questions until today. I bought a parts catalog for GL1000K3 and GL1000z and found the answer so I will share with you this information that may be useful to other GL1000 fans.
Greetings from Poland
Pawel
Honda Silver Wing 2001 - sold
Honda Deauville 2010 - sold
BMW R1200RS 2015 - present
Honda GL1000 1978 - present
Prospect
Zinc Member
Zinc Member
Re: Frame number GL1 vs GL2
Post by Prospect »
Czesc Pawel. Piekne zdjecia.
Can someone chime in with regards to some differences between the European models and US? I know in the SOHC bikes it was mostly the rear turn signal lights and brake lights that were different.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
I’m vaguely recalling a longer rear fender on European models as well.
Lucien Harpress
Post by Lucien Harpress »
Yup, longer rear fender due to the larger licence plates (as compared to US models). I've also seen horns that are forwatd-facing and lack the chrome cover, but I have no idea if this was factory.
(I've kept an eye out on and off for a longer rear fender for my bike, just for fun. I think they look neat. Nothing cheap enough to pull the trigger on though.)
Paola Zago
Post by Paola Zago »
As far as I know, the differences between European models and US models are: lighting system, with the possibility of traveling even with the lights off, position light, which consists of a small bulb inside the front light positioned under the main bulb, and with independent manual operation, the tail light comes on with the position light. Obviously then normal low beam and high beam light (for France the bulbs were yellow) there is no parking light with stationary vehicle. American high handlebar only in the first models imported at the end of 1975 and beginning of 1976, then the "European" handlebar, I think code 53100-371-960, is mounted, which is slightly lower than the one visible on the Resenok GL. and finally long rear fender. A round taillight was fitted only for Germany. I don't think other differences.
MattMcCoy
Post by MattMcCoy »
Good info. Anyone know if cable lengths are shorter for Euro GL1000 handlebars?
1983 GL1100A Aspencade
1977 GL1000
1978 GL1000
1979 GL1000
“I see Angels on Ariels in leather and chrome,
Swoopin' down from Heaven to carry me home."
pidjones
Post by pidjones »
MattMcCoy wrote: Tue Nov 09, 2021 9:51 am Good info. Anyone know if cable lengths are shorter for Euro GL1000 handlebars?
I run "Euro bars" on my Hunley '78 with '75 motor. I have routed the clutch cable over the top of the air cleaner on that side to take up the slack for it. So far, the throttle cables have not posed a problem.
MattMcCoy
Post by MattMcCoy »
pidjones wrote: Tue Nov 09, 2021 12:42 pm
Appreciate it.
1977 GL1000
1978 GL1000
1979 GL1000
