'78 Paint Question
tomk1960
'78 Paint Question
Post by tomk1960 »
I was wondering if anyone has found a good match for the "Candy Limited Maroon" that was used in 78 and 79? Perhaps House of Kolor has something that works? I might have my bodywork repainted over the winter and if my painter can avoid having to reinvent the wheel to come up with a match, that would be great.
Thanks.
1986 VFR750F Interceptor
1978 Honda GL1000
flyin900
Re: '78 Paint Question
Post by flyin900 »
If no one has an option then a body shop supply house usually has an optical scanner, if you have a decent painted panel to scan. It will match and formulate something very accurate.
On my 1981 GL1100 I had the shelter scanned and a paint formulated for it and I actually blended it into the existing paint. Unless you are a critical paint expert, no one can tell where I blew in the panels with the new paint.
Current Bikes:
pidjones
Post by pidjones »
https://www.rsbikepaint.com/en-us/shop- ... 7&22732=on
I used their Geneva Green on my '76 Yamaha RD400c and it seems a perfect match to the original. Only 1/2 pint was more than enough. This is a water borne paint and MUST BE CLEAR COATED. In fact, it look awful until the clear, then the metallic and color pop. Sprays like a lacquer. Shipping costs as much as the paint, but the total still isn't bad.
tomk1960
Post by tomk1960 »
flyin900 wrote: Mon Nov 08, 2021 7:47 pm If no one has an option then a body shop supply house usually has an optical scanner, if you have a decent painted panel to scan. It will match and formulate something very accurate.
I'm not sure how easy it is to match with a scanner since there's usually a metallic base coat and then several coats of the candy. Unlike a solid color, candies take several coats to achieve the desired shade, so getting a good match with a scanner can be difficult. My painter will do a scan, then experiment on a sample piece to get the coat count right for the color.
pidjones wrote: Tue Nov 09, 2021 12:48 pm https://www.rsbikepaint.com/en-us/shop- ... 7&22732=on
This is good to know - I'll tell him about this option. All of the pieces will be repainted, so a perfect match to original isn't necessary - something close will be great since the bike is somewhat modified anyway.
Thank you both for the suggestions!
1978 Honda GL1000
flyin900
Post by flyin900 »
As a follow up to my response. The GL1100 was a metal flake dark blue/black colour from the factory. I don't believe Honda was doing the really multistage paints of the 60's and early 70's on the same level. I blew in and matched the panels on sections of the shelter and it would take a really experience painter to see the blend.
I suggest you look at both options, as I bought my paint for about $50.00 from the body supply place and have lots left. It was a custom mixed pint of paint that I used a minimal amount. Definitely enough to shoot the few panels on a Wing.
Current Bikes:
Shadowjack
Post by Shadowjack »
I refinished a tank from a 71 CB500 that was candy green from the factory. It was actually candy blue over a gold basecoat... No wonder there were never actual Honda paint codes from those days. Silver basecoat: blue. Gold basecoat: green.
