Coolant leak 75'
Re: Coolant leak 75'
For me I use scotchbrite to clean the sealing surfaces and then I wipe a very light coat of clear rtv on the sealing surfaces just before assembly. I do this because the surfaces tend to not be all that smooth after all these years of service and it gives me leak-free operation.
I keep saying this: RTV means Room Temperature Vulcanizing, which refers to any rubberlike compoind that doesn't require heat to cure.
????Sidecar Bob wrote: ↑Mon Nov 15, 2021 9:46 am I keep saying this: RTV means Room Temperature Vulcanizing, which refers to any rubberlike compoind that doesn't require heat to cure.
You probably meant silicone sealant when you said "a very light coat of clear rtv" but RTV can refer to any of a number of rubberlike compounds.
Bob, not trying to be a smart aleck here but I’m trying to understand the point of your post. I know that RTV means Room Temperature Vulcanizing, and I’ve used several different brands/types (not water soluble Type) and know you can’t use it in conjunction with gasoline or brake fluid as both dissolve RTV, so please help me understand what I’m missing here.
If you mean silicone sealant you should say silicone sealant. RTV is not necessarily silicone.
Sidecar Bob wrote: ↑Wed Nov 17, 2021 3:15 pm If you mean silicone sealant you should say silicone sealant. RTV is not necessarily silicone.
- Dr. Frankenstein
Those Laser bits are for the hand-held 'hit-me-with-a-hammer' type, but I love these - they of course fit into my electric impact driver, but when it comes to working on old bikes they are indispensable. I have both types, depending on how big the problem is:
DSCN1843 by Dr. Frankenstein1, on Flickr
Get 'em here: $18 and worth every penny!
https://www.amazon.com/B4633-Screw-Driv ... B085TDRBPM
- Zinc Member
Installed the orings on both crossover tubes and installed new gaskets. I pinched one badly but I didn't have any spares so I had to use it. I ran the engine for about two minutes (first start since early 90's) and didn't see any leaks. This is my first water cooled bike so this might some dumb but does the pressure inside the cooling system increase with rpm? I'm wondering if the pressure increases with rpm would a leak show at higher rpms that doesn't at low due to pressure increase. Since it was a first start I didn't run the engine too high.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
The pressure in parts of the cooling system near the output of the water pump will have higher pressure and that would increase a bit at higher RPM. BUT the pressure increase from the coolant trying to expand as the engine warms up is so much greater that any increase near the pump's outlet at higher RPM won't matter (not to mention that the pressure in parts of the system near the pump's inlet will be lower at higher RPM).
And then there's the thermostat. When the engine is cool the thermostat is closed, limiting the amount of coolant that can be pumped through the system until the engine warms up and the thermostat opens. Generally the system won't reach full pressure (regulated by a valve in the rad cap) until the thermostat has opened.
In other words, let it warm up a while and see if it starts to leak.
BTW: Any engine will warm up faster at varied throttle openings and under load, which means riding it if possible but at least revving it up to 2-3,000 during the process.
- flyin900
FYI, If you ever bought the Princess Auto large red plastic Metric O ring assortment kit (200+ O rings in various sizes) it frankly is pretty useless for almost any Honda correct sized O rings. Yet a number of years ago I had this kit and discovered it has an O ring that is a perfect fit for these coolant crossover tubes.
There are a few other O rings that can be used as Honda subs, yet you need to buy this kit on sale for dirt cheap, for it to be worth while.
Current Bikes:
I bought the assortment in the smaller translucent white box from Princess and it had a couple of sizes that were close enough to work and used them up on the winter machine over a period of several years (Honda specifies the same o-ring for the water pipes on the CX/GL500/650 family as they do on 4 cylinder GoldWings). When they ran out I bought a lot of 50 on Bay, as well as similar lots of other sizes I'd found I used a lot of and I've been using them since, except when I bought gasket sets that included o-rings and at the rate I've been using them I may just have a lifetime supply of some sizes.
A few notes about o-rings:
- Honda lists the sizes of o-rings by the INSIDE diameter and the cross section (wire) diameter
- A lot of the o-rings Honda used when these bikes were made are actually inch sizes with the dimensions converted to metric (hence all those odd sizes)
- Rubber is flexible so o-ring sizes don't need to be absolutely precise.
As an example, Honda specifies a 21.9 x 2.3mm o-ring for the water pipes. You will never find a 2.3 or 2.4mm cross section o-ring from a regular supplier but you will find 3/32" cross section o-rings.
BUT a 2.5mm section o-ring is only 8.7% larger than a 2.3mm diameter one and a 22mm ID o-ring is only 0.46% larger than a 21.9mm one so there should be absolutely no problem using a standard 22mm x 2.5mm o-ring on the water pipes.
FWIW, the ones I bought for water pipes are similar to the 27x22mm ones in this listing.
https://www.ebay.ca/itm/174310594026
- sickradsean
Partzilla has all the O rings and gaskets available. Waiting on mine to show up.
1977 GL1000 "Goldie"
- 20 Replies
- 884 Views
Last post by 77Gowing
- 8 Replies
- 363 Views
Last post by scootsx2
- 1 Replies
- 165 Views
Last post by Whiskerfish
- 4 Replies
- 180 Views
Last post by ericheath
- 14 Replies
- 458 Views
Last post by salukispeed
