Coolant leak 75'
- Zinc Member
Coolant leak 75'
I noticed a coolant leak from the coolant cross tubes. It's coming from the one on the left side of the bike. It's very small but I'm sure as soon as I start circulating and running the bike it'll be a lot. I'm new to the GL1000. Can somebody recommend what the best way to approach this leak is?
- PXL_20211110_181116509.jpg (190.62 KiB) Viewed 361 times
- PXL_20211110_181343190.jpg (210.14 KiB) Viewed 361 times
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- Lucien Harpress
Re: Coolant leak 75'
The two screws connect the elbow to the head, and everything else is press fit together with o-rings.
Remove the screws, get some new gaskets and o-rings, make sure the crosstube isn't damaged, and replace.
Probably the easiest coolant leak to fix on these bikes.
- Zinc Member
Silly question. Do I need to drain the coolant before I do this? I just put all new coolant in there. Are the gaskets and orings still available from Honda?
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- Lucien Harpress
Pretty sure you have to drain the coolant for this. I've re-used coolant before, especially if it's that fresh, so you may as well drain it.
From what I can tell gaskets and o-rings are still available from Honda. The gaskets are part number 19429-371-306 and the o-rings 91301-MB6-003.
#1 - get a #3 JIS screwdriver. #2- smack the crews smartly to break corrosion binding free. Try hard not to break the crews removing them, they are prone to snap off. Clean the tube OD, elbow and manifold IDs well and lubricate the new o-rings with silicone grease. Use a new gasket between the elbow and the head.
- Zinc Member
Miraculously I was able to free the screws using my impact driver - an essential tool.
I'll order the parts and report here.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
Get the proper Honda o-rings, grease them before assembly, and do all of them.
I bought a lot of 100 o-rings the correct size to fit those pipes and all the pipes on my CX too for a few $. When I had the 'Wing engine apart I bought a kit and used the o-rings from it but I've used the eBay ones on the CX in the past and thy sealed OK.
Before you put it back together polish the places that the rings have to seal against with a ScotchBrite (remember to clean off any of the abrasive residue afterward).
Lubricate only the outer edges of the new o-rings after they are in place on the tubes (this helps keep them from twisting) and use only silicone grease on them because petroleum based greases will cause the rubber to deteriorate prematurely.
For the gasket you can either order one from Honda or if you have gasket paper you can cut your own in a couple of minutes. All of the engine gaskets except for the head gaskets can be cut from 0.8mm (1/32") gasket sheet that you can buy at any auto parts place. I usually buy it as 18" x 36" rolls from CTC (Fel-Pro #3023 - it isn't on the website but it is usually on the shelf) and save the offcuts from bigger gaskets for things like the joint (elbow) gaskets. The hardest part of cutting your own gaskets is making the bolt holes but I bought a set of hollow punches at Princess for that and it became easy.
For the outside of the gasket, place the cleaned part on the gasket material and trace around it with a ballpoint pen, then punch the bolt holes, drop bolts through them to align the part with the sheet and gently press around the edges of the opening to mark the gasket. Once that is done you can cut the gasket out with scissors, a sharp knife or a combination of the two.
BTW: Did the leak appear when you ran the engine or did you find the puddle on it after storage? When I had the 1000 engine in my 'Wing and stored it in an unheated shed for the winter there was always a tablespoon or so of coolant on top of the engine in the spring but it never leaked when running...
- Zinc Member
The bike leaked after a week of sitting in a heated basement. I'm going to do both sides while I am at it.Sidecar Bob wrote: ↑Thu Nov 11, 2021 1:17 pm I bought a lot of 100 o-rings the correct size to fit those pipes and all the pipes on my CX too for a few $. When I had the 'Wing engine apart I bought a kit and used the o-rings from it but I've used the eBay ones on the CX in the past and thy sealed OK.
I have a set of about 100 o-rings as well that I use for my other bikes. I'll check to see if I have the correct size. The size is 21.9x2.5. Thanks for the excellent tip on using silicone grease. I wouldn't have thought of that. When I looked at the o-rings they looked brittle so I'm not surprised they leaked.
I'm going to buy the gasket from Honda. Hopefully they're available.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- Lucien Harpress
Be sure to check the sealing surfaces too for any damage or imperfections. I remember the metal of the cross tubes being shockingly thin, and it wouldn't take much to deform it. The edge is real good at slicing o-rings too, if you're not careful. Don't ask me how I know...
PID’s advice on the JIS screw driver is some of the best you’ll get, they work waaaaay better than a common Phillips head that tends to “cam” out and strip the cross out of the screw. Best advice a friend (thanks Ed) ever gave me, they just work better.
- Zinc Member
I have JIS screw drivers but I don’t have a set of bits for the impact driver. I need to buy a set.
Current Bikes
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
1969 CB750 Sandcast
1971 CB750K1
1972 CB750K1
1975 CB400F
- flyin900
I think PartnMore or Sirus Consolidated sell just the bits with the standard hex back end for the driver tool. Located in Kitchener area, so a little more local than US sellers.
Current Bikes:
- LuckyEddie
I use these in my impact driver. You should be able to find them on Google to aquire some.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
- sickradsean
Funny that this thread just got posted as I've apparently developed the same issue! I noticed some white smoke coming off the left headers the past few times I've started my bike (while still working through other issues).
I checked and found a small amount of coolant puddled on the top of the engine under #2 carb. Apparently I's been dripping down the outside of the valve cover and onto the headers.
You can see the wet header bolt here. Judging by the amount of gunk under there (you can see where I wiped some off), this has been going on for a while. What I thought was a small exhaust leak and the typical start up smoke, has been coolant all along!
1977 GL1000 "Goldie"
- 20 Replies
- 884 Views
Last post by 77Gowing
- 8 Replies
- 363 Views
Last post by scootsx2
- 1 Replies
- 165 Views
Last post by Whiskerfish
- 4 Replies
- 180 Views
Last post by ericheath
- 14 Replies
- 458 Views
Last post by salukispeed
