Not much of my goldwing has been pulled apart over the 30 years of ownership in our family , looked at articles on swing arm , mostly to remove them and lube needle bearings . After looking at parts drawings and pics , I decided to mark the pivot bolt and lock nut , then measure from frame to end of pivot bolt (11.5 mm)
Put bike on center stand , removed one pivot bolt and put a large lump of wheel bearing grease on the end, the needle roller is capped so the grease gets hydraulic-ed into the bearing , reset measurement , double check the " right in and back out 1/8" . All good .
Gl1000 swingarm lubrication
- Zinc Member
76 GL1000 ,73 Norton mk5 , 75 Triumph T160 , 49 Matchless G80 500 rigid ,and
X4 76 HondaTL250s
X4 76 HondaTL250s
Re: Gl1000 swingarm lubrication
Something we should all do every 30 years or so. Probably one of the neglected areas. New swing arm needle bearings can be hard to find but are available.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
- tlbranth
Got needle bearings here: https://www.vxb.com/SearchResults.asp?Search=bk2518p
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- 11 Replies
- 755 Views
Last post by Shadowjack
- 545 Views
Last post by Gc33
- 4 Replies
- 296 Views
Last post by ericheath
- 4 Replies
- 403 Views
- 160 Views
Last post by BobInNashville
