'76 GL1000 Clutch actuation question
Haleydr82
Brass Member
Brass Member
Post by Haleydr82 »
Hello all, and Happy Thanksgiving to those that celebrate it!
I have a quick question and I'm hoping to get some feedback from the group.
I'm currently working on rebuilding the motor from a '76 basket case and I'm buttoning up the clutch cover. I wanted to try and test the functionality of the clutch by hand but found that I'm unable to make the actuator arm (not sure if that's the right terminology) budge.
Should I be able to move the clutch actuator by hand, or does it take more pressure than I'm able to exert?
Thanks in advance!
Dave
Dave
1982 Standard GL1100 - SOLD
1976 GL1000 Project Bike
2007 GL1800 Daily Rider
Lucien Harpress
Re: '76 GL1000 Clutch actuation question
Post by Lucien Harpress »
It's going to take a lot more than just operating the throw out arm by hand. The clutch lever imparts quite a bit of mechanical advantage.
If you get the motor close to the bars you may be able to jerry-rig a setup with the lever and cable to bench test things. But yeah, don't worry about not being able to move things right now.
Haleydr82
Brass Member
Brass Member
Post by Haleydr82 »
Lucien Harpress wrote: Wed Nov 24, 2021 4:23 pm It's going to take a lot more than just operating the throw out arm by hand. The clutch lever imparts quite a bit of mechanical advantage.
Great, that’s what I was hoping to hear. I appreciate the quick response!
Dave
With the engine out of the frame, now will be the perfect opportunity to check the clutch assembly free-play before the engine goes back into the frame.
note: if you haven't adjusted a clutch free-play before, loosen the locking nut and turn the adjuster screw counterclockwise (out) 1 turn to increase the free-play dimension, first. Then following the clutch arm free-play adjustment directions, you should be able to turn the adjuster screw clockwise (in) to sense the first internal contact, utilizing your fingertips, only.
This Topic might be useful?
viewtopic.php?f=54&t=68393
Cliff (74yrs ;) )
Haleydr82
Brass Member
Brass Member
Post by Haleydr82 »
gltriker wrote: Wed Nov 24, 2021 5:41 pm With the engine out of the frame, now will be the perfect opportunity to check the clutch assembly free-play before the engine goes back into the frame.
Thanks Cliff! That link was very helpful, especially the information regarding the expected free play of the lever.
Dave
Haleydr82 wrote: Thu Nov 25, 2021 12:55 pm
tumb2 you are welcome
Cliff (74yrs ;) )
