How to disconnect rear shock low air pressure red light on dash
tallnwise
Post by tallnwise »
Hi guys,
Santa is bringing me Progressive 412s for my 1980 GL1100.
How do I permanently disconnect the low air pressure electricals so that the light doesn't come on?
I am not electrically inclined -- any simple fix (apart from black tape on meter face)?
Also, there is a flat washer on the stem of one of the 412 shocks which seems loose -- is that normal?
Thanks in advance.
Regards,
Dan
1980 GL 1100
Re: How to disconnect rear shock low air pressure switch
Cliff (74yrs ;) )
BlueThunder
Re: How to disconnect rear shock low air pressure red light on dash
Post by BlueThunder »
Remove the bulb??
...Brian
1977 GL1000 - Ox
tallnwise
Post by tallnwise »
thanks -- saw somewhere I can try grounding the wire near the rear master cylinder, will try that -- else will go with the bulb approach.
1980 GL 1100
5speed
Post by 5speed »
I didn't do anything to my bulb as it went out after the bike started. I thought it was strange that it did but took it as a win. I recently changed the bulbs to led ones and now it stays on. lol
I'm just going to remove the bulb.
DUGG
Post by DUGG »
tallnwise wrote: Sat Dec 04, 2021 9:23 am thanks -- saw somewhere I can try grounding the wire near the rear master cylinder, will try that -- else will go with the bulb approach.
IRC I think I crimped a ring terminal on and used one of the master cylinder bolts to ground it.
Oldewing
Secretary
Secretary
Post by Oldewing »
Yep, wire by rear master, ground it out, light stays off. Mine has been off since 2001.
tallnwise
Post by tallnwise »
Thanks guys -- will go the grounding route, once I "officially" unwrap Santa's present ;-).
1980 GL 1100
DUGG
Post by DUGG »
tallnwise
Post by tallnwise »
DUGG wrote: Sat Dec 04, 2021 6:48 pm 9264E05A-EBF6-47E4-821E-4D034ACA467D.jpeg
Nice, thanks for sharing. Just what I needed.
Do you run Progressives too?
Best,
Dan.
1980 GL 1100
5speed
Post by 5speed »
tallnwise wrote: Sun Dec 05, 2021 10:21 am
Best,
Dan.
I'm running progressive shocks on mine. they're series 12
DUGG
Post by DUGG »
Best,
Dan.
I run the progressive 12 series in the rear and progressive springs in the forks. Shock Preloaded in the middle notch. Riding solo or two up and fully loaded no problem
The stock air shocks would bottom just riding two up no gear even with 90 pounds of air pressure in them. Switch to the progressives and never look back.
I’d like to find a tach that doesn’t have the warning light in one of these days. I plan on eliminating the air fittings on the forks at some point too.
tallnwise
Post by tallnwise »
Thanks @5speed and @DUGG, looking forward to installing and riding with mine.
I did upgrade the front forks to progressive springs couple of years ago, definitely made a positive difference.
Have a good one.
1980 GL 1100
