Stripped head bolt threads
- Old Fogey
Well, I guess it had to happen some time. Never had a probelm with all the engines I have rebuilt, but fortunately this is my own bike, not a customer engine.
This is the 79 GL1000 that has been sitting dead since I bought it many years ago. I found so many problems that I basically lost interest in it. However, I need the space so it needs to go. So knowing that the left head was leaking I pulled it, cleaned it and the valves up, new valve seals, lapped valves and went to refit it. I had cleaned the treads in the block with a tap, nothing much in the way debris removed, so greased up the bolts and got to maybe 30 ft/lbs and one bolt let go. So, ok, lets see if any othersare going to do the same. Sure enough, another one at about 35 ft/lbs.
That is a real bummer.
So, anyone got ideas on fixing, preferably in frame? With my spinal problems I'm not supposed to be pulling 200lb engines onto the bench (tho I will if I have too!). I guess Helicoils would be one answer but that's a big ask to get them drilled straight in frame.
EDIT: well, just looked at an old thread from 2013 with someone doing exactly that. So I guess I get ordering a Helicoil kit.
Re: Stripped head bolt threads
Hello John!
Taking into consideration the need to keep the HeliCoil pilot drill bit straight , I wondered if putting the cylinder head back onto the engine, if there is diameters' clearance in the bolt hole, would possibly serve as a makeshift drill bit guide .
Cliff (74yrs )
- Old Fogey
Hi Cliff,
I ordered a Helicoil set last night. The drill would not be long enough to go through the head and down into the block, unfortunately as that would had been one answer. My best bet is someone else eyeing it from the side while I check it from the top. I'm going to do all 6 as I don't want to do those two and have another strip, besides not trusting any threads that are left to hold a final torque. I was going to overhaul the other head as well, but i guess not!!
i would think that the original bolt hole (providing the bolt isn't broken off in the hole) would suffice as a pilot hole to keep the drill going straight. Just keep an eye on the depth and you should be ok to drill it out with the helicoil drill bit and then tap it for the helicoil. Use cutting oil for both the drill and tap.
-P.
-P.
- Old Fogey
Thanks for the reply. Robin also said the same thing in a PM. No broken bolts, just no thread left. but I will still have another pair of eyes on it, just to be sure.pjlogue wrote: ↑Mon Dec 06, 2021 7:21 am i would think that the original bolt hole (providing the bolt isn't broken off in the hole) would suffice as a pilot hole to keep the drill going straight. Just keep an eye on the depth and you should be ok to drill it out with the helicoil drill bit and then tap it for the helicoil. Use cutting oil for both the drill and tap.
-P.
Some hand drills have a built-in level, but I've never trusted them. You could jig up a fixture to attach a spirit level to the drill to keep one axis correct (assuming the engine level).
I would try making a drill guide out of a piece of hardwood that was thin enough to let the bit reach but thick enough to keep it square.
have you tried googling the drill bit size to see if you can get an extra long one that would allow you to use the head as a guide?
- Old Fogey
Thanks for the thought. As yet I have not but that thought had crossed my mind.
Making this way too difficult.
Or way over thinking it. Take your pick.
- Old Fogey
Well...........maybe. But anyway, I have ordered a long series 10.3mm drill. The way my luck has been lately I need to take all the precautions I can.
- 6 Replies
- 273 Views
Last post by CYBORG
- 28 Replies
- 860 Views
Last post by Oldtech
- 0 Replies
- 2020 Views
Last post by Whiskerfish
- 22 Replies
- 852 Views
Last post by jdvorchak
- 484 Views
Last post by bthacker
