Chain orifice removal?
luigipasto
Zinc Member
Zinc Member
Post by luigipasto »
Hi, I was trying to remove the chain orifice, the shiny thing just below the oil supply nozzle on the GL1000 (part # 15530-371-000). On some videos I noted it was being reinstalled with a screw driver, but the hole at the top of the chain orifice is round? Any idea how these are removed? Thanks...
1975 GL1000, on the road but patiently awaiting restoration
1976 GL1000, in the middle of a frame-off restoration.
Re: Chain orifice removal?
# 15 here in this pic if anyone can help.
chain orifice.jpg (50.64 KiB) Viewed 228 times
luigipasto
Zinc Member
Zinc Member
Thanks Whiskerfish, it appears not many have tried to remove this part??
Been a few years since I have had one down that far and I just can not remember what I did there.
I have a couple of bare blocks, and wwill look later, but I seem t recall it just pulls out.
Oldewing
Secretary
Secretary
Post by Oldewing »
CYBORG wrote: Tue Dec 07, 2021 9:15 am but I seem t recall it just pulls out.
my vote..
flyin900
Post by flyin900 »
+1 on the above as age and that O ring is likely holding it in there. If the O ring is available then some penetrating fluid and a little heat from a hair dryer, or heat gun should have it pull out easier.
Definitely worth clearing out the orifice and the oil supply passage.
Current Bikes:
it just pulls out, but yeah it can take some pursading
luigipasto
Zinc Member
Zinc Member
OK, I'll try some penetrating oil before reaching in with a long-nose plier, just worried about damaging it, but I'll let you know...Thanks to all for the info.
luigipasto
Zinc Member
Zinc Member
I finally managed to get the oil orifice out! There's no place to grab onto it so long-nose pliers were out. I found a Phillips head screwdriver just slightly smaller than the opening at the top of the orifice. I wrapped the head of the screwdriver with several loops of black electric tape. I then pushed the head of the screwdriver into the orifice, turned the screwdriver a few times so that it fit into the orifice like a plug, and it pulled right out. It was so easy it actually surprised me to see the thing at the end of the screwdriver. I'm almost done emptying out the case, one more bearing to pull out....
luigipasto
Zinc Member
Zinc Member
Oh, and no need for penetrating oil. The small o-ring on the orifice is still available so might as well replace that in a rebuild....
yes replace the o-rings
