Neutral light out after clutch adjustment
- Cakey
Hi team and Merry Xmas. I did a full clutch adjustment today as per the manual instructions. When finished it improved the 1st gear not being so clunky when putting it into first gear from neutral, but now the neutral light doesn’t work and I have to pull the clutch in to start it. Any advice on what I have done wrong? Feedback appreciated, thanks.
1975 Gl1000
Re: Neutral light out after clutch adjustment
It’s probably the silicone diode (the brown thingies) under the left shelter panel. Check your service manual for which one it is. I just went through this a couple of years ago. Sorry I don’t remember which one of the 4 it is, someone here may pop-up on which one exactly it is, but that’s what I’d say it is. Let us know how you do.
Note: I just looked at my post from When I had this problem and PID here helped me, it’s the diode with the light green wire with the red stripe, PID gave me some great info on all this, good read ! good luck !
- Lucien Harpress
Hm. Neutral light out + needing to pull the clutch to start it makes it sound like the bike thinks it's still in gear.
-Have you confirmed the bike is actually in neutral?
-While the bike is running and you shift from 1st to 2nd, do you get any momentary light out of the light as you shift through neutral?
I doubt the clutch adjustment caused this. Probably as reglbx noted a diode went out (coincidence) or more likely poor connections (happens on these old girls). There are several sets of diodes - and one set is for the neutral safety circuit. Once you check the connections, just try swapping the diodes.
- Cakey
Well it’s not the diode. I am sure it’s something to do with me doing the clutch adjustment. Could it be the clutch switch? When I fiddle with that it starts playing up. I am not sure what the clutch switch does though……
1975 Gl1000
- Lucien Harpress
Basically it locks out the start button if the bike is in gear and the clutch lever is released. A bad clutch switch would explain the no-start if the lever isn't pulled, but not necessarily the bad light.
- Cakey
So I just took off the clutch lever and the neutral light comes on. As soon as the clutch lever depresses the switch everything stops working. The switch is in the correct place but as soon as anything touches it,it cuts out the neutral light. If it’s not depressed, all good. Any ideas? Is there a work around?
1975 Gl1000
From what you’re saying it sounds like you have a bad clutch lever switch, don’t know if you can fix that w/o just replacing the switch. My .02
The theory behind the clutch switch is to provide a ground path from the starter solenoid when pulled, completing the power circuit from the starter button through the solenoid. The neutral switch also provides this ground path, which also turns on the light. The diode is between the neutral switch and the clutch switch, so that pulling the clutch doesn't create a second path to ground from the neutral light and turn it on, whether it's in neutral or not.
The starter should work when EITHER the clutch is pulled, or when it's in neutral, assuming both switches are good and the wiring is connected properly. If the diode is shorted, the neutral light will come on when the clutch lever is pulled. If the diode is open, the starter will not work when the clutch lever is pulled.
- Cakey
I have since checked my diodes with the multimeter on the highest ohms setting. When tested both ways by swapping over the posited and negative leads there was no reading at all. Does this mean bad diode.at the moment I took the clutch switch off the clutch and left it under the tank shelter so the button doesn’t depress. Just means the neutral light doesn’t go out at all.Shadowjack wrote: ↑Tue Dec 28, 2021 9:44 am The theory behind the clutch switch is to provide a ground path from the starter solenoid when pulled, completing the power circuit from the starter button through the solenoid. The neutral switch also provides this ground path, which also turns on the light. The diode is between the neutral switch and the clutch switch, so that pulling the clutch doesn't create a second path to ground from the neutral light and turn it on, whether it's in neutral or not.
1975 Gl1000
Test the diodes on the continuity setting, not the highest ohm. There should be a connection in the one direction and none with the leads reversed. Sorry mine did fail but I do not recall if it failed short or open. Seems like it was short.
- Cakey
Thanks Fred. Now checked on the continuity setting I think I have it sorted. The diodes are reading nothing one way and about 990 the other way. I did have two bad ones in the group that were 003 and 026 each way. This leaves me to think that it could only be the clutch switch. The neutral switch is brand new Honda.Fred Camper wrote: ↑Tue Dec 28, 2021 4:48 pm Test the diodes on the continuity setting, not the highest ohm. There should be a connection in the one direction and none with the leads reversed. Sorry mine did fail but I do not recall if it failed short or open. Seems like it was short.
1975 Gl1000
Here is the manual page for the diodes.
All of the diodes are the same. Swap another one in to test.
This drawing is for the later models that have the regulator and regulator in one unit but the part you need to understand for your issue is basically the same.
- 9 Replies
- 2994 Views
Last post by chewy999
- 7 Replies
- 709 Views
Last post by robin1731
- 1 Replies
- 130 Views
Last post by JOLLY
- 4 Replies
- 225 Views
Last post by trat
- 3 Replies
- 277 Views
Last post by Track T 2411
