Tweaked front forks.
I just finished a 76 project and went for a test ride and noticed that the handlebars and gauges are a few degrees off from centered. What is the cause of this? Bent triple tree maybe? I put an angle finder on the forks and there appears to be about a 2-1/2 degree difference between the angles of the forks. Is it going to take a new triple tree to fix this?
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
Re: Tweaked front forks.
Cliff (74yrs )
I found a video on you tube on aligning the front wheel by loosening everything on the front end but the top punch bolts then adjusting it like I use to straighten my bicycle handlebars when I was a kid and tighten it all back up. It worked! Runs straight and true now.
Perfect!
Cliff (74yrs )
Yep, was going to say, loosen some stuff up, give her a twist and a shake, and it’ll straighten right out.
A friend who is a Honda trained mechanic taught me to loosen everything except the upper clamp's pinch bolts and then sit on the bike with the front wheel against a wall and bounce the suspension as hard as you can a few times to align the front end (tighten everything back up afterward),
Works every time.
Works every time.
- 4 Replies
- 198 Views
Last post by Roady
