GL1000 carbs clear tube question
kerryb
Post by kerryb »
'77 GL1000, 758A carbs from a '76. Carbs recently cleaned (twice for good measure, with randakks kit) new OE float needles and seats. Floats set to spec at 21mm. all seats are sealing properly with no leaking over timed test.
So I'm testing bowl levels with the clear tube method remembering the level should be 2-3 mm below the bowl seam and have begun to question my method. I did this same thing last fall on my '83 and it ran great for 2000 miles, but this is on someone else's bike, I won't be able to ride test it till spring, and I'd like to get it right the first time.
The picture shows the carbs in test position sitting very close to level. but the carbs themselves are sitting at an angle to each other that is not level. So the question is which part of the bowl seam do I measure from? there is around 5mm difference from inner edge to outer edge, so I could be off by 8mm by picking the wrong one. I think I need more educating here to get it closer to "right"
All comments welcome, it's all part of the adventure.
static level test
static level test
float test.jpg (104.36 KiB) Viewed 249 times
current level at 21mm float height
float level.jpg (84.56 KiB) Viewed 249 times
Re: GL1000 carbs clear tube question
That looks a bit high to me BUT I have never doe that method. I just put them upside down and hit them with a vacuum and lift each float one at a time. When they hit level I expect them to start sucking.
kerryb
Post by kerryb »
Thanks, I thought they looked too high too, but it was still only an opinion. I'm going to lower the level and wait for more opinions before putting them back on the bike. Found it is easier to remove and replace carbs when they are still attached to the motor! Just don't forget the neutral switch wire...that one is really tricky
05c50
Post by 05c50 »
As I understand it, float height/fuel level is measured so as to allow the fuel level to the main jet to remain as close to constant at all times (idle, accel, decel, cornering). With that in mind, the fuel level should be measured near the main jet tower which in almost all carbs is in the center of the float bowl. I've never seen anything about GLs, but on other carbs that sit at an angle, the instructions say to take the measusement at the center of the length of the carb.
.........Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
cfairweather
Post by cfairweather »
I use the clear tube method each time I do a set of carbs. I have carefully measured the float level with a gauge on many sets and then looked at the level in the tubes, so I know where the level should be. I fine tune the levels to be exactly the same on all four carbs. It is also a good way to verify the float valves are working properly. Check the level on the carb rim that is closest to you as if the carbs are mounted on the bike. This edge is the lowest edge. When checking the level, push the clear tube right next to the rim at the same place on each carb. The ideal level should be at the lower edge of the rim. The level can be a bit higher, but don't go beyond the middle of the rim. I connect an electric fuel pump to make sure the float valves get properly stress tested. If one leaks you will know it because the level will go way high and sometimes flow out of the carb.
kerryb
Post by kerryb »
Thanks.
Excellent info! This should be moved to ShopTalk so it doesn't get buried!
Lucien Harpress
Post by Lucien Harpress »
These opinions are just my own, but here goes-
Personally? I think this method, while it has merit, is more useful determining proper float and/or float valve operation than setting a useful float height. The manual gives fuel level setting based on a float height, and setting that float height and THEN using that to determine fuel level via clear tube is just giving you the same information in two different ways.
(I say this because my KZ1300 gives the fuel height setting ONLY via the clear tube method, and it's a royal PITA, not to mention it's supposed to be done with the carbs level, an orientation GL carbs naturally aren't. I wish Kawasaki would've just given me a float height and made things easy.)
But, as said, just my two cents.
I’ve only set them per the book and as Randakk suggests also, but this method checks float height as the liquid closes the float and seals. The other way assumes the float will seal in its gravity closed position. It may have merit but it must be time consuming.
Shadowjack
Post by Shadowjack »
Seems like this is a good error-check for uniformity in the levels. Everybody screws up sometimes.
cfairweather
I set the level using a Randàkk gauge and usually have one carb where the level is a bit off compared to the other three. Typically, all four fall into the acceptable range that I described above. It only takes me a few minutes to drain the fuel and pop the carb bowl off and make a minor adjustment. I then recheck and adjust again if needed. I usually can do this in 15 minutes or. so. I always only lightly snug down the bowl screws until I fully complete the level check. The only way to be sure the levels are correct is to perform this procedure. I check for vacuum leaks too before installing the carbs. It does take some time, but it is time we'll spent.
