smelling antifreeze when bike starts
Re: smelling antifreeze when bike starts
My experience tells me that it IS a headgasket........and it won't get better if not changed. And it won't fail untill you are at least 100 miles from home
RIP: cookie
Or ... possibly ... 2500 miles from home ...
Gord :IDTS: anim-cheers1 :IDTS:
Sagebrush
Post by Sagebrush »
If you change one do them both.
5speed
Post by 5speed »
He's going to go with the water pump now as it needs to be replaced. If it is a head gasket and it leaves him stranded..I'll get a call. :mrgreen:
sickradsean
#20
Post by sickradsean »
could also be bad O rings/gasket in the coolant crossover tube. I would get a puff of white smoke mid engine and a coolant smell on startup when the headers got hot enough to burn off the drips that had seeped out.
1977 GL1000 "Goldie"
#21
Yep. Crossover tube leaks run down into the sparkplug wells and out the drain holes right onto the headers. A definite possibility esp if the bike has spent any significant time sitting.
5speed
#22
Post by 5speed »
Whiskerfish wrote: Tue Jan 11, 2022 9:38 pm Yep. Crossover tube leaks run down into the sparkplug wells and out the drain holes right onto the headers. A definite possibility esp if the bike has spent any significant time sitting.
I will pass this on to him.
tks guys
#23
Rat wrote: Tue Jan 11, 2022 3:49 pm Or ... possibly ... 2500 miles from home ...
but you can put it in the back of a u-haul to get home... or so I have heard
redglbx
#24
Post by redglbx »
Too, it’s probably a head gasket as I’ve had a similar deal with bubbles in the coolant, it’s not uncommon to have the bubbles and nothing in the cylinders, this is because you have 130-171psi compression vs 6-7psi coolant pressure, so the less viscous compression more easily pass’s through the head gasket.
Have you tried retorquing the head(s) yet ? Sometimes you get lucky and reseal the head gasket but most times not but it may get better. See if you reduce or eliminate the bubbles in the coolant. I would also pull the spark plugs to find where it’s leaking because the cylinder with the leak the plug will look steam cleaned.
Have you looked at your oil ? If it is leaking through the water pump the oil will look like a chocolate milk shake but a water pump (loose impeller is not good ) will not create bubbles in the coolant! You probably have more than 1 problem here.
toomanybikes
#25
Post by toomanybikes »
redglbx wrote: Wed Jan 12, 2022 10:40 am Too, it’s probably a head gasket as I’ve had a similar deal with bubbles in the coolant, it’s not uncommon to have the bubbles and nothing in the cylinders, this is because you have 130-171psi compression vs 6-7psi coolant pressure, so the less viscous compression more easily pass’s through the head gasket.
Haven't tried re-torquing the bolts and the Triumph is ~fourth in the winter project queue, but I'll take a look before Spring riding season hits. Oil hasn't changed color and plugs were normal last I checked.
Greater Boston MA, USA
5speed
#26
Post by 5speed »
he checked his plugs and all were the same. No sign of steam cleaning. He hasn't see any bubble in the coolant, just a small bit of oil.
#27
a small bit of oil could easily be from a bad water pump
5speed
#28
Post by 5speed »
rcmatt007 wrote: Wed Jan 12, 2022 2:57 pm a small bit of oil could easily be from a bad water pump
and his is bad.. which reminds me..I forgot to order one. oops. lol
digger
#29
Post by digger »
I concur with Cyborg, personal experience is, the head gasket is just starting to fail. Run it the way it is, but may be a long way from home when it goes.
NotSoLilCrippseys
#30
Post by NotSoLilCrippseys »
I used that kit on our '83 project last winter. Worked great for my son and me.
In the Stable and Ridable
1992 XJ600S - son's streetfighter
1983 - GL1100I - naked Blue Phoenix (son's, really)
1982 GL1100I - naked bagger Cabernet
1978 CB550K - son's cafe (carb issues still vex)
Active Project(s)
1979 GL1000 - Confirmed one owner, with original paperwork. Vetter fairing and bags, off the road in dry, heated storage for 35 years.
Sold
