Carburetors
Re: Carburetors
There is a kit available (Randakks had it) to fix the float pivot post. Unless you use one of the major rebuilders (all here on NGW) or do it yourself, expect problems. I've heard of way too many Honda shops and small shops botching carb rebuilds. Done yourself with care and attention to detail, they will only need redone two more times (at least, that's what it took me my first set).
Re: Carburetors
The 1100 carbs are indeed smaller and they use 4 of the 1100 specific anti-backfire diaphragms which are fairly expensive usually around $25 each. My experience with the 1100 carbs has been that they reduce the performance on a 1000 across the board and my experience has been that they generally will not rev more than about 6500rpm. But this is easily fixed by reducing the main jets from 145’s to 140’s and then they seem to rev fine to the 1000’s 8500rpm redline.
Now let me add that with smaller bores and the accelerator pump they SHOULD have better low end and better drivability. But again a well & PROPERLY setup set of 1000 carbs will outperform a set of 1100 carbs in my experience. But those that know me will tell you that I run 1100 carbs on my 76 but as I said earlier I have modified the hell out of them with a lot of machining time in them to improve the airflow through them. If you can match the same airflow of a bigger opening with equal or better airflow through a smaller opening you increase the airflow velocity which is better all around and will better atomize the fuel in the airflow and that increased velocity will improve the vacuum signal across the board with sharper throttle response as well.
Jetting, jetting is just a function of matching fuel metered into airflow to get you an acceptable fuel to airflow ratio, the ideal ratio is called “stoichmetric” and is 14.7 parts air to 1 part fuel, but that leaves little room to prevent any lean induced damaging knock. So the accepted thing is to run the air to fuel ratio (a/f) richer to prevent that. Honda did a couple of things here, they ran the a/f ratio very lean at the low end with the 35 idle jets and the 62 main jets which in my experience Gives you a 15-15.5/1 ratio which is very lean, this is done for emissions testing which is usually done up to around 2500rpm and is a self certified deal done by the manufacturers. They compensate that super lean condition then with super rich 120 secondary main jets that I’ve seen generally run in the 10parts air to 1 part fuel which is just pig rich and begins when the slides start to lift the needles out of the jets.
This is done to avoid warranty claims caused by the super lean condition damages in the lower jetting and to also help with the often complained about cold bloodiness, but again if you properly setup your super cleaned carbs this is all minimized. My .02
- RIP: cookie
Re: Carburetors
At least a nickel's worth I'd say …
Re: Carburetors
Re: Carburetors
Ok so how do you do a bench sync to get the carbs close im a little poorish cant afford to get the sync tool or the vaccuum test also anyone know what else I can use off the 81 on my 77 I see the 81 has air shocks in the rear
Re: Carburetors
Burns, sorry to say but there is no way to sync your carbs well on the bench. If you use a drill bit or gage pin to get the throttle blades in the neighborhood but actually using vacuum gauges to sync your carbs compensates for differences in valve adjustments, compression differences cylinder to cylinder as well as differences in port diameters and textures as well as probably many other things that I’m not remembering right now. The only way to do this right requires vacuum gauges to adjust the carbs to compensate individually.
Watch eBay for a used set or check with friends who might be willing to help, join a local bike group and maybe someone can help. Sorry but there’s just no way to do this off the bike properly, as I said earlier if you set the throttle blades to be the same on the bench you may get lucky and have it good enough. Sorry but that’s the way it is. Where are you located ? Adding that and your bike info to your profile may help identify where you’re at along with maybe somebody close & willing to help.
- gregforesi
Re: Carburetors
Really. The extra 11-12hp that my dyno run showed is useless?
2006 GL1800 (Brutus Maximus)
- dontwantapickle
Re: Carburetors
I'd really like to know more about the dyno results.
Re: Carburetors
Re: Carburetors
Burns, a 0.004” feeler gauge is a good place to start a bench sync. You may have to loosen the other three to get the base carb to just touch the gauge. Try to get the other three the same. Then when you increase the throttle stop screw, all move together. You don’t want to slide it more than enough to feel it’s snug-ish. It doesn’t take much to leave a mark in the throttle plate’s edge.
I can get them pretty close by closing the throttle plate down on the three holes in the bore. I try and cover half of the hole.
The syncing order is different on some bikes. One side has only one adjuster. The one on these side is the base carb. It can’t be adjusted except by the throttle plate. Match the one next to it with the base carb. Then go to the other side and match the two carbs using the middle adjuster. Last is matching one side to the other side with the last adjuster which is rearward of the back carb.
Re: Carburetors
Greg, I would love to see your torque dyno curve ! The Wings that I’ve ridden with Weber’s have all been the single carb version which imho give a great low end punch but really suffer at the upper rpm. But they also tend to be much smoother running (no sync issues). 11-12hp is a significant increase, don’t know if that was just tongue-in-cheek but Randakks dual Weber setup does seem to work.
Also, don’t know if you’re looking for more but milling the heads .040in (you an go up to .050in) and optimizing the cam phasing and I believe you would be in the 90hp at the rear wheel range. I find the fuel curve interesting as well, it has that “glut” where it goes really rich that I think is from the accelerator pump hit and then your Weber’s get fairly lean where the oe carbs go really rich to around 10-1a/f , 10.5-1 a/f . Very interesting ! Thanks ! These old girls can make some horses, not compared to the current stuff but respectable !
Just looked at the date and see that it was 10yrs ago,,still cool !
Re: Carburetors
Re: Carburetors
I kinda assume I have a vaccuum leak somehere during cold start the bike idles roughly 1100 rpms but once it gets a little bit of heat in the bike the rpms jump up to anywhere from 3k to 6k rpms
Re: Carburetors
Burns, a couple of thoughts & questions. Does your bike have one of the vacuum petcocks ? Does the rough idle occur when it’s warmed up after being run or only when cold started. Does it do this when run frequently or only after sitting for a length of time.
The reason I ask is that this sounds a lot like normal Honda starting when it’s sat for a length of time or has one of their vacuum petcocks and is the result of low or no fuel in the carbs & improves once the carb’s are filled. If it happens all the time then I would suggest you check that the fuel filter is not restricting flow or maybe a sluggish fuel pump. The service manual recommends a flow test in it but I don’t have that in front of me currently. What year is your bike ?
To check for a vacuum leak it can only be a few things, the joints of the intakes or around the throttle shafts on the carbs. I use a can of wd40 with the straw to spray around each joint with the motor runnng and if the idle picks up then you’ve found your leak.
Re: Carburetors
Could be a vacuum leak for sure. Also check for the required free play of the throttle cable. If it does not have the recommended slack it will do this.
- 22 Replies
- 1666 Views
Last post by Dr. Frankenstein
- 0 Replies
- 295 Views
Last post by ericheath
- 14 Replies
- 786 Views
Last post by pidjones
