GL1000 1976 - Head gasket
Re: GL1000 1976 - Head gasket
I've yet to have a problem with the coolant o-rings. Lube well with silicone grease, make sure the sealing area on both inner and outer surfaces are clean and smooth, and install the o-rings on the tubes first, then insert into the sockets.
^^^ This ! I use Permatex red assembly lube on mine, very slippery stuff.
Thank u all guys for your answers. Appreciate your help !
As she has Dyna S, could the hotter right side (cylinder 1 and 3) be caused by an ignition/advance trouble.
May I try this time adjust : https://www.ngwclub.com/forum/viewtopic.php?f=22&t=5720 ?
GL1000 1976 - smooth and unstoppable, be aware ur safety distance
SRX 600 1987 - stroke and agility, catch me if u can
https://www.youtube.com/channel/UCMB875 ... WWNj5MtKAw
https://soundcloud.com/nicdes
The right hand ignition coil is responsible for ignition to cylinders 1 and 2. Front right and front left respectively.nicdes wrote: ↑Sun Apr 17, 2022 7:11 pm Thank u all guys for your answers. Appreciate your help !
Sharing the same Dyna S module.
The left hand ignition coil is responsible for ignition to cylinders 3 and 4. Rear right and rear left respectively.
Sharing the other Dyna S module.
There are other factors that could cause or contribute to the engine issues that are causing you distress.
But first answer this. Are you definitely replacing a cylinder Head gasket?
Cliff (74yrs )
OMG sure ! I misread and misunderstood the explanation. Cylinder (1 &2) and (3 & 4) ! Thanx !gltriker wrote: ↑Sun Apr 17, 2022 7:48 pm The right hand ignition coil is responsible for ignition to cylinders 1 and 2. Front right and front left respectively.
I want to be sure that head gasket(s) is the thing. I suppose that most of the time, it's not a cause but a consequence, and maybe something else has to be changed. My coolant is very dirty and seems to have floating black pieces of plastics, like parts of an O-ring. I guess I will have to check the full coolant circuit : radiator, waterpump, thermostat etc...
For the head gasket, I'm not so scared about making it but I know how "time eating" it can be. I already done it a few years ago on a dohc saab car. It was after a fan failure...
Cliff (74yrs )
If you have bubbles in the coolant recovery tank you have a blown head gasket. No maybe, no other possibilities.
You need to figure out which gasket is blown. The side that is hotter could be the culprit but it is also possible that the coolant entering the combustion chamber is cooling the head with the bad gasket so a more specific diagnostic approach is needed. See this thread for my method of finding which gasket was leaking
https://www.ngwclub.com/forum/viewtopic.php?f=1&t=73408
Thanks for this clear diagnosis Bob !
Many say that if I have to do one, I shall make 2 and change both right and left.
Anyway, I will try to figure out which one is down !
Attached, a pic of what was left in the coolant circuit.
I don't agree with that. Why disturb one head when there is nothing wrong with its gasket. Would you change the light bulb in the living room because the one in the kitchen stopped working?
BTW: Your pic isn't showing.
- Lucien Harpress
It's all personal preference of course. I tend to lean the other way, for a couple of reasons. While easier than most bikes, getting to the head gaskets is still a non-trivial repair, and if you've gotten it down this far, you'll save yourself time later by getting them both done at the same time. (By the same reasoning, it's a great time to freshen up the top end as well- valve guide seals, lap the valves, etc.)
Second, while your other gasket may still be good, it's also the same age as the one that failed, and these bikes have the annoying tendency to lose both head gaskets at roughly the same time.
But, as said, your bike, your rules. While there's plenty of "wrong" ways to do a head gasket replacement, whether you do 1 or both is NOT one of them.
Hi,
A pic of the waterpump. Im not surprised It's the old bakelite one. Looks good and not a 1/32" move or play.
I guess I'll stop investigate further more this way and mount the cover back...
- dontwantapickle
What is that black stuff floating in the coolant?
If it is rubber, It's possible that your hoses may be braking down.
It was not really rubber, more a kind of coagulate grease. But I plan to change the hoses anyway as they look scratched and weak
So nicdes, let me ask you on your cars head gasket,,,,,, was it a “Saab” story ? Sorry couldn't help myself !
So on a serious note,any idea of what that is in the coolant ? Never seen anything like that before. Probably need to really flush your coolant system to make sure all of that is out.
One thing I would suggest to help identify which one is bad is to run the bike until it’s fully warmed up, shut it off and pull the plugs, most time the bad gasket will produce steam out of the plug hole.
On the water pump, in spite of all the known issues with the Bakelite water pump impeller I am a fan of it as it is a more efficient design, now ask me what I have in my bike(s) ,,,,, hint,,, it’s metal !
Head gaskets,,I am not a fan of changing head gaskets just because unless they have failed, but Lucien’s comments for freshening the top end up with new valve seals (can be done w/o taking the head off) cleaning and lapping the valves is valid, but if it was running good before the head gasket failure, Itend to leave it alone. But as I said earlier you could mill the heads to clean up the surface very well and increase the compression a bit, but it is your bike & your choice.
Hi,
I found a pro mechanic close to my area who accepts to check and clean the radiator.
I already have ordered and received a new calorstat and shall let the bakelite waterpump in place. If the radiator is ok, it will go back to it's place with new hoses. This way, after a good flush, I shall restart dearest miss GL and try to identify which head gasket is dead.
My short mechanic experience has showed me a few times that the less I touch the better for the engine, so I'd really prefer to find and replace the bad gasket (if only one is involved...).
- 12 Replies
- 363 Views
Last post by robin1731
- 36 Replies
- 3783 Views
Last post by FADM Stern GNSF
- 30 Replies
- 978 Views
- 299 Views
Last post by Sidecar Bob
