Final driven gear noise
- Chainman
Hello all,
I noticed my mpg had dropped and suspected I was dragging the rear brake.
I pulled the rear pads and then heard noise in the final drive.
I tried to remedy by changing the gear oil, and cleaning and greasing the splines. It didn't seem to help.
Please have a listen to this and let me know what you think
- Chainman
Re: Final driven gear noise
Fixed your first post. Sounds like the rotor scraping on the brake housing to me. Can you see if that might be happening? Last time you had the wheel off are you certain the spacing tube was inside the final drive?
- Chainman
Thanks for fixing the post.Whiskerfish wrote: ↑Sat Apr 30, 2022 6:14 pm Fixed your first post. Sounds like the rotor scraping on the brake housing to me. Can you see if that might be happening? Last time you had the wheel off are you certain the spacing tube was inside the final drive?
I am certain the spacer is between the bearings
The gear oil did look a little metalic.
I'll have a hopeful look at the rotor clearance and report back
Thank you
- Chainman
Removing the pads eliminates the rotor noise.
Maybe the bearings then; hopefully. This bike did sit for 33 years
Anyways, grateful for this forum
Yep, I’d replace the wheel bearings, but I’d bet you already knew that.
- 05c50
Loosen the 3 nuts that hold the final drive to the swingarm and back the axle nut off. If the noise changes (mine did) tighten the nuts and axle in the proper sequence. I heard the same noise on mine when I would push it around the garage. I think it comes from a slight mis alignment of the spline on the rear driven flange.
.........Paul
.........Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- Chainman
- Chainman
I'll try today, thanks05c50 wrote: ↑Mon May 02, 2022 8:17 am Loosen the 3 nuts that hold the final drive to the swingarm and back the axle nut off. If the noise changes (mine did) tighten the nuts and axle in the proper sequence. I heard the same noise on mine when I would push it around the garage. I think it comes from a slight mis alignment of the spline on the rear driven flange.
.........Paul
Good idea Paul, never hurts and it’s free !
- 05c50
Haha, I'm all about "free".
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- Sagebrush
I'll sayHaha, I'm all about "free".
- 05c50
Okay, enough from the peanut gallery.
.......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- RIP: cookie
I’m here to say he’s actually very generous … I’ve proved it in past visits …
Note that the correct order is
1) axle nut (this will pull the splines into alignment)
2) swingarm pinch bolt (all models except GL1000)(if you do that first tightening the axle nut will pull the ends of the swingarm together)
3) final drive nuts
3) final drive nuts
- 6 Replies
- 258 Views
Last post by Sagebrush
- 14 Replies
- 927 Views
Last post by luigipasto
- 6 Replies
- 299 Views
Last post by Psycheonabike
