Hi all,
I just received a caliper from a breaker that has helicoils in the carrier (for mounting to the fork. So I contacted the breaker by email and asked if I could send it back.
Then I took my own caliper off (my barnfind came with only one caliper, hence why I bought the second from the breaker), and it was the same. Including the fact that the helicoil is nowhere near full length.
So.... is it possible they came from the factory like this? Or is it just a common thing fro people to break and repair with a helicoil?
Do you think it is safe enough to use with this repair, or should I be looking for undamaged ones?
Cheers
Alan
Brake Caliper mount - helicoil?
- Zinc Member
- 20220526_091910[1].jpg (137.77 KiB) Viewed 318 times
- 20220526_091835[1].jpg (154.09 KiB) Viewed 318 times
1976 GL1000 barnfind, not run since 1991. My first Goldwing, which joins my 1990 Suzuki VX800 in the stable.
Re: Brake Caliper mount - helicoil?
A properly installed helicoil is stronger than the aluminum
On mt1200 I have helicoils in both of my caliper brackets. No problems
- Zinc Member
Thanks guys. I decided to keep the helicoil repaired caliper, but for peice of mind may lock wire the caliper bolts.
- LuckyEddie
Also, you can stack the helicoil inserts, one after the other to complete the repair and use the full length of the hole which will increase the holding power well beyond the original specs.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
- 21 Replies
- 834 Views
Last post by tallnwise
- 229 Views
Last post by clhiller
- 4 Replies
- 259 Views
Last post by chewy999
- 225 Views
Last post by maintainer
- 349 Views
Last post by flyday58
