Electronic Ignition Test Light ON All the Time
- Dr. Frankenstein
I feel like I should know this now after performing timing adjustments, but it's been a while and this is my first attempt at electronic ignition.
I have a new electronic ignition installed, identical to the one cfairweather outlined in his recent posts, and tried to time it according to THIS post:
viewtopic.php?f=22&start=45&t=5720&sid= ... b7b604e49a
...but what does it mean when the test light stays on all the time? for example, to set the timing on the F2 mark, I put one test lead on the blue/white wire connector as outlined in the above post, ground out the other to the frame as seen in the post pics, and the light came on; I turned the crank to the F2 mark, and the light stayed on all the way around. Same thing for the F1 mark - -
Battery is fully charged...
Ignition switch is On...
Spark plugs are wired up to the coils...
...and the red lead from the E-I is attached to the right screw under the Accessory box, seen here but before I put the lead on...
DSCN2293 by Dr. Frankenstein1, on Flickr
I did run a jumper from the spaces for the two black-braided wires in the center of the connector that came off the original ballast resister, that cfairweather says to connect with a jumper - you can see the loop here - that I figured would do the same thing...everything else I matched up to where the original blue and yellow wires AND the other two black/white wire entered the connector so I could put it back into the connector...how does this look?
DSCN2321 by Dr. Frankenstein1, on Flickr
So why is my test light staying ON all the time?
Re: Electronic Ignition Test Light ON All the Time
There's a couple of reasons. Is the red wire securely attached to an active switched positive terminal?
https://www.mpsracing.com/instructions/ ... /DS1-3.pdf
Another Dynatek document for your files. See the last sentence under the VOLTGE TEST section.
https://www.mpsracing.com/instructions/ ... esting.pdf
Easily overlooked-
make sure you have an uninterrupted path to ground where the DynaS baseplate mounts in the formerly occupied by breaker points' cavity.
Corrosion can hide under adjacent surfaces on the ground path from the cylinder head, itself, past a hidden gasket or 2.
Screw threads are not reliable to assure a low resistance ground path. Corrosion will accumulate in their hidden threads.
Newly painted surfaces are very efficiently insulated where it shouldn't have been applied.
A quick way to test for a ground path issue is to run a temporary jumper wire from the negative battery post to directly touch the Dyna S baseplate.
Too loose Dyna S baseplate clamping screws will cause a similar issue with the test light .
A breaker points' baseplate and their primary ignition circuit may be more tolerant of a less than perfect ground connection in comparison to the Dyna S modules' demands.
The positive current path coursing through the red wire, independently, operates the ground switching circuitry in both Dyna S modules.
Easily overlooked-
Cliff (74yrs )
- Dr. Frankenstein
Well, here's what I have:
Plugs are connected, the switch is On.
Here is the connector the original wires from the coils were plugged in to; note that since I am using the upgraded coils, I have removed the ballast resistor entirely and have run a jumper (that black-wire loop) into those original spaces in the connector, because I read that's what you're supposed to do when using the new Dyna coils. All the other wires (color-wise - the yellow, blue and black wires)) have been reinstalled in their original positions.
Notice the test light here is connected to where the white wire from the E-I connects to the Blue wire, and the light is On...this light stays on even as I rotate the engine
DSCN2335 by Dr. Frankenstein1, on Flickr
On the other one, the black wire from the E-I is connected to the Yellow/Green wire, and the light is Off; this light stays off even as I rotate the engine:
DSCN2336 by Dr. Frankenstein1, on Flickr
The red wire from the unit is plugged into the other red wire from the unit (seen here) and that wire is attached to the Accessory panel under the left shelter, which you Can do as an option outlined in the Dyna instruction sheet you listed. With a freshly-charged battery reading 12.52 volts I have 11.78 volts at that Accessory connection point
Also, taking your advice I ran a jumper from the Negative battery post to the Dyna baseplate, and got nothing: the light stays off. The screws on the baseplate are tight, and I have also sprayed down the connections with contact cleaner, but still have No Joy. All the wires coming from the coils - the yellow, blue and the two black ones that screw into the coils themselves and go into the black plastic connector - are tight;
What am I missing?
What am I missing?
Hey there John!
I just woke from a morning nap, am watching a mini-marathon of Roadkill and opened my laptop to read this.
My first groggy impression is that you have somehow combined both primary negative circuit wire connections, Together.
A couple of years ago a fellow had been struggling with a mangled wiring connection under the rubber boot. Seems he was dealing with a light continuously on. Still using points and condenser though. BUT, we know that now removed component and its two plug-in wires are not in the theater where you are working, anymore.
His photo of that area suggested he had plugged both primary leads from the points into the same double terminal connector. Both condenser leads were plugged into the other double terminal connector. Something like that. When he attempted to start the engine with both primary leads connected together, chaos ensued. Yes, our suspicions were fact.
So..... just for fun, put all 4 spark plugs into their wires, lay them on the engine, and just for fun, crank the engine over.
Be very mindful, FIRST, that if gasoline is expelled out of the spark plug holes while cranking the engine over with a nearby sparking spark plug ...... a Fire may happen there
Are all 4 spark plugs firing in concert with each other? Yes? How fun was that!!!
Not trying to have fun at your expense.
In the photos of my 1975 GL1000 primary wires' details with Dyna ignition coils installed that I had provided for your prospective DC1-1 ignition coils installation, on pre-1978 GL1000 bikes, you noted the visual simplicity of bullet connectors.
Your 1978 GL1000 black plastic multiple wires' terminals and the jumper is where my suspicions lead to.
Whoa! Just thought of something. Work with me now.
Unplug both Dyna S leads from their respective double socket terminal under the rubber boot.
Turn on the key switch and handlebar switch. Now, Test from a good ground connection for the presence of positive current at both double socket terminals. Positive current presence at both double socket terminal confirms both ignition coil has a connection to the positive terminal of the battery.
Call my cell phone. It is on, 24/7.
Cliff (74yrs )
- Dr. Frankenstein
Hey Cliff! Are you kidding me?? I'll take any fun I can get these days, at my expense or not...remind me to tell you the story of the 'hungover-frozen-water-pitcher' sometime. And I'm a Monster Garage guy myself - but I'd still like to put together a motorcycle restoration show; it's all cars on TV these days... (any producers out there??)
Anyway, I'll try the spark-plug thing sometime today; with temps in the mid-90's here today, it's hotter than a redheaded debutante in the lab...the shop fan helps, but, yeah, it's steamy in there. Reminds me of working in my dad's machine shop when I was a kid. And there's not yet any gas in the tank, so no worries there. In twenty-something years of rebuilding bikes I've only had one "Holy ****!" moment with gasoline - but I still keep an extinguisher in the garage to this day.
Re: the connector wiring, that does seem to be the weakest link in this electrical chain I have going here but I don't know why, all the wires are where they should be going - I feel like the answer is right in front of me. Oh, I'll get it, but if anybody has any information to hasten this "Eureka!" along I'd love to hear it!
Yeah, I went back to the other topic where you displayed the 'new' DC1-1 ignition coils and the detail of the placements of the very long blue, yellow, and both black primary wire assemblies you had, Correctly, there, installed onto their respective screw terminals.
I get lost amongst the other photos and conversation.
Yes. Perform the dynamic engine cranking test experiment. Do all 4 spark plugs discharge, simultaneously?
Perhaps not even one spark plug will discharge.
Is the DYNA S rotor spinning while you are cranking the engine over with the electric starter? No?
The Advancer Driving Pin is missing?
Left side camshaft's, Timing Belt? Its Pulley been removed for any reason? Its Key missing?
Finally, I now have no more thoughts to offer , John.
Done
Done
John, have you exclaimed,"Eureka!" , yet?Dr. Frankenstein wrote: ↑Fri Jun 17, 2022 1:04 pm Hey Cliff! Are you kidding me?? I'll take any fun I can get these days, at my expense or not...remind me to tell you the story of the 'hungover-frozen-water-pitcher' sometime. And I'm a Monster Garage guy myself - but I'd still like to put together a motorcycle restoration show; it's all cars on TV these days... (any producers out there??)
Cliff (74yrs )
- Dr. Frankenstein
No, not yet - I even had an electrical engineer friend of mine take a look at it, he seems to feel it's something in the unit itself; a bad grounding, maybe...? I'm hoping I didn't get a defective one, but I'm also trying to chase down what it Could be.
So, you did check my last 3 guesses then ?Dr. Frankenstein wrote: ↑Thu Jun 23, 2022 7:57 pm No, not yet - I even had an electrical engineer friend of mine take a look at it, he seems to feel it's something in the unit itself; a bad grounding, maybe...? I'm hoping I didn't get a defective one, but I'm also trying to chase down what it Could be.
Cliff (74yrs )
- Dr. Frankenstein
No, not yet - As you know I've been a little busy here dealing with other stuff - however I can confirm the advance driving pin IS present.
"Left side camshaft's, Timing Belt? Its Pulley been removed for any reason? Its Key missing?"
- Not since I changed the belts when I first got it...and I made sure the timing marks matched up on the wheel...
Dr. Frankenstein wrote: ↑Thu Jun 23, 2022 8:13 pm No, not yet - As you know I've been a little busy here dealing with other stuff - however I can confirm the advance driving pin IS present.
trouble shoot the DS1-1 system with this Dynatek document. Won't require an oscilloscope or other exotic test equipment.Dr. Frankenstein wrote: ↑Thu Jun 23, 2022 7:57 pm No, not yet - I even had an electrical engineer friend of mine take a look at it, he seems to feel it's something in the unit itself; a bad grounding, maybe...? I'm hoping I didn't get a defective one, but I'm also trying to chase down what it Could be.
DC volts and ohms measurement capability are all that's required for these simple tests. The typical multi-meter is perfect.
But, first thing verified, it will demand positive current is actively coursing, independently, through the GL1000 wiring harness' yellow and blue primary leads to their respective double female terminals, under the rubber boot, when the key switch and handlebar switch are both selected to their Run positions..
That is a Must Have requirement in order to perform the VOLTAGE TEST steps with the DS1-1 rotor's magnet aligned with each DS1-1 pick-up module, then not aligned with each DS1-1 module pick-up .
Don't overlook the "red" wire necessity to operate the DS1-1 pick-up modules' internal switching circuitry.
Yes, I have personally performed this Dyna S system testing, two different times on a hot engine.
(Neither time was the DynaS I tested determined to be problematic)
An electrical engineer friend is a perfect candidate for the DS1-1 ignition system tests. You can do it, too.
Cliff (74yrs )
- Dr. Frankenstein
Well, FWIW, I was finally able to go out and test for spark, but (1) I have no spark on cylinders 2 and 4, and (2) it cranks without stopping, even after I hit the kill switch! - I had to disconnect the Neg battery connection to get it to quit! So Yah, there's an electrical FUBAR in there somewhere. Man, I hate electricity...
I have had this problem before, with one of my Dreams, I think: I just can't remember the remedy. Anybody?
GL start relays are notorious for sticking ON also.Usually a sharp rap with a screwdriver handle will temporarily jar them loose. If you are truly back-feeding into the starter relay pull-in circuit, you really do have a wiring mess.
- Dr. Frankenstein
"If you are truly back-feeding into the starter relay pull-in circuit, you really do have a wiring mess."
The bike was in neutral, but I didn't have to pull in the clutch to crank it over; if so, Any idea how to check/fix it...?
And still no spark...
Take the battery out and go over the circuits one at a time with a meter using the wiring diagram as your road map.
- 9 Replies
- 793 Views
Last post by elslimdiablo
- 5 Replies
- 444 Views
Last post by Sidecar Bob
- 6 Replies
- 355 Views
Last post by BlueThunder
- 4 Replies
- 794 Views
Last post by ericheath
