Clutch problem in 79 GL1000?
- Rusty Probie
as the title suggests my 79 wing with approx. 49,000 miles has a habit of making a muffled screech once in a while when starting out. The bike doesn't stall when this happens it just sort of lurches forward like the clutch was popped. The clutch works good otherwise, no slipping and disengages smoothly with no dragging, I've had the bike for about 9 years and have changed the oil every 2,500 miles with Shell Rotella. The bike is stock except for a home brewed intake with a 1970's hitachie carb from a Subaru. Any idea what might cause this?
- Lucien Harpress
Re: Clutch problem in 79 GL1000?
Does it do it more often when it's cold?
My bet's on clutch plates. Probably slipping a bit before grabbing (hence the lurch). Mine was doing something similar, and new plates cleared it right up.
- RIP: cookie
Any material on the oil screen ?
Is this just recently ?
- BlueThunder
I would adjust the clutch properly and go from there.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Spline Negligence ?
https://ngwclub.com/forum/viewtopic.php?f=1&t=77253
Couldn't locate a photo though of the environmentally more vulnerable final driving output splines, that need to be serviced during every rear tire replacement session,
But, this ShopTalk maintenance tutorial should be helpful:
https://ngwclub.com/forum/viewtopic.php?t=17275
The propellor shaft's u-joint located under the flexible rubber boot can be a point of failure, too. Check there, first?
(my Trike doesn't have that Final Drive, Output splines configuration. Final Drive, Input splines components. Yes. )
Cliff (74yrs )
- Rusty Probie
Thanks for the replies. This gives me some things to try to eliminate this problem, John
- 17 Replies
- 602 Views
Last post by desert_indian
- 4 Replies
- 149 Views
Last post by robin1731
- 9 Replies
- 281 Views
Last post by gscloner
- 8 Replies
- 295 Views
Last post by Easter
- 8 Replies
- 421 Views
Last post by redglbx
