I know a guy.
plenum or petcock
Re: plenum or petcock
Definitely, a "Seasoned Pro" guy
Cliff (74yrs )
for sure Cliff, i promise. incidentally I appreciate the edit on an earlier post. 'glaringly obvious' is the name of the lead character in the movie of my life. played by Brad Pitt obviously...
yeah, although I do that occasionally when addressing a posed to the group question, after I recognize its been seen, removing it soon afterwards is good form.
I haven't been riding my trike for 2 years. If I can help others with their ride, it's good for my head.
Brad Pitt, eh?..
Brad Pitt, eh?..
Cliff (74yrs )
Before throwing in the towel, you need to determine what is leaking. Your description certainly sounds like a leaking float needle, but could be a carb-to-plenum gasket, a fat oring which seals the fuel port from carb to plenum, or it could be the plenum seal.
You’ve observed step one of diagnosis, turning the fuel off causes it to run better for a short time. To determine what is leaking, you need to go a step or three further. Each case will eventually require removal of the rack eventually, but not necessarily a full strip down rebuild, even though it is highly recommended so you aren’t doing it again next year.
1. Suspend a liter or more of fuel six feet above the bike, by-pass the fuel pump by hooking the inlet going from your source to the carb rack direct. A longer hose is helpful. (I’ve done this just bypassing the the fuel pump and having a full tank of fuel, but it might not generate enough working pressure to simulate the pumps pressure.)
2. Remove the air cleaner cover and air box and filter. Dry off the floor of the plenum. Cut and place a piece of paper towel or absorbent paper in the floor of the plenum so it sits flat on the floor. With the bike level, turn the fuel on with a flashlight handy and observe whether fuel shows up along the centerline of the plenum floor or towards one of the carburetors. If it’s along the centerline, it’s your plenum gasket.
You’re probably done, but the other checks could rule out other issues.
3. Undo the eight bolts holding the intake elbows so the rack can slide each way. Remove the elbows. They require heating the rubber and an up and down motion to get them started. (Worst part of the job)
4. Remove the two screws holding each carb cap, then remove, mark/label and keep together each cap and slide.
5. You should now be able to slide the rack towards each side enough to gain clear view into the carb throats. If not, you might need to undo the choke cable and throttle cables at the rack. No need to remove them from the bellcrank yet. (But likely)
6. Make sure each throat is clean and dry and the rack is level. Have your flashlight handy, and turn the fuel on, looking into each throat for the first sign of fuel. You’re trying to determine if fuel comes up through the brass jet(s) first or if it comes from the area between the jets and plenum. I’ve had all three.
If it comes from the jet first, it’s your float needles. If it comes from the plenum side, it’s your carb-to-plenum seal.
The plenum seal and carb-to-plenum seals can be replace without a full tear down, but the float needles will require bowl removal, float removal which is tedious if the pin the float rests on is stuck, and getting the seat for the needle out is often no picnic either.
The linkages will allow the racks to fold like an accordion to replace the plenum seal or the carb inlet seal at the plenum.
There is an offset connector for each choke mechanism. It will likely fall out if doing the carb-to-plenum seals. Get them back in place before reassembly. It only takes six tries. A piece of tape might help if you can get your finners in there.
Rebuilding the carbs is very doable, but requires care. My first set resulted in a destroyed rack of carbs. The PO gave them a head start with stripped float bowl screws. I broke a tower for the floats, and committed many faux pas along the way. There are good vids available now.
appreciate you chippin' in mate but first mention of the carbs having to be removed and that towel got chucked in... don't have the room, light, tools, experience or inclination. banjaxing the carbs with the best of intentions will just leave me with a duff bike stuck in a doll house.
i'm willing to try a Seafoam flush (or the Berryman B12 if i can get my hands on any) running out the fuel in the carbs repeatedly in the hope whatever is stuck will dislodge.
should that fail, i'll pull the plugs and crank the engine and whichever hole gas sprays out of should indicate which carb has a stuck float. i can then drain that bowl and see if it makes a difference.
i'll also remove the air box and hope to see a dry plenum floor.
if none of that works, its the phone book and me passing on my findings to someone who knows what they're doing. sure, $$$, but sometimes you just gotta bite that bullet
Just beware of "mechanics" that don't really know these carbs. Too many have taken their GoldWings to folks that have never worked on one, only to be stuck with a bill and barely-running bike.
As PID says ! I have redone a number of carbs that “experts” have supposedly done that had wood screws & sheet metal screws holding things together ! I have a 80 1100 currently that a friend took to an “expert” and payed a lot of money to and had it sit in their shop for months only to get it back in barely running condition with wood screws holding the bowls on. Currently it won’t run at all but it will pop.. just piss’s me off to see this kind of stuff.
The “expert” is a self proclaimed GW all knowing guy, he just effed these carbs up ! I hope they are salvageable going to need a bunch of helicoils at the least.
Helicoils are cheap on Amazon. Well, not true Helicoils, but if you have a true Helicoil kit they go in with the same tools.
it's in the lap of the gods, just like everything else. if my semi-articulate knuckle dragging methods won't work, i'll have to leave 'er into a shop and put my faith in someone who may or may not give a flyin' one. but that's the nature of the beast when you've reached the apex of your 'limit:' in all its connotations...
tonight i thought i'd run out the gas in the float bowls with the petcock off, then when the idle started to dwindle, turn it back on for a second or two, then off again and repeat a couple times.
that thing ran for ages. ages. in the 'off' position. farted, spluttered, and smoked like philip rothman if i revved it still in 'off' but kept running... how much do those float bowls hold for crying out loud? or is there something else amiss...
Under power like when you leave a gas stop with the petcock off you can usually get 2 or 3 miles before it dies. Not that I have ever done that
Sure glad that I’ve never done that
- Lucien Harpress
Yeah, GL carbs last a while. My KZ? She'll only get about 200 feet.
- Sagebrush
If it were me in your situation I would find a mechanic with enough skills to remove and replace the carb rack. I would then send the rack to Robin for rebuild. The only thing that you may have to do is synch the carbs once they are reinstalled.
- 24 Replies
- 774 Views
Last post by ericheath
- 325 Views
Last post by Sidecar Bob
- 31 Replies
- 1215 Views
- 9 Replies
- 397 Views
Last post by mfnheff
