1000 Plenums
redglbx
1000 Plenums
Post by redglbx »
So let me ask,,,, are all gl1000 plenum’s interchangeable & the same ? I believe they are but not sure. I am working on a carb set off an LTD for a friend that keeps leaking into the plenum, so today I found porosity & a very fine crack at the upper fuel port. Took me some time to figure where the fuel was coming from but I found it today, first time I’ve ever seen this out of the many sets of gl carbs I’ve done !
So just keep this in mind if you have a leak that you can’t seem to fix, I had fuel flowing into the plenum from the area around the number 1 carb, i have replaced the plenum gasket/seal and the carb to plenum seals (all Randakks ) several times but it still leaked and seemed to be getting worse. Even giving the good folks at Randakks a good piece of what’s left of my mind did not help relieve the leak,so we’re down to replacing the plenum, hence the question about interchangeablility. Thx guys !
Re: 1000 Plenums
As I recall reading some years ago, the 1975 carburetors' flange-to-plenum connection did not utilize the 2 solid round stock alignment pins that the 1976-1979 carburetors benefit from. ( I could be wrong though? )
Cliff (74yrs ;) )
redglbx
Re: 1000 Plenums
Post by redglbx »
Thanks Cliff !
redglbx
Re: 1000 Plenums
Post by redglbx »
Something that has come up through all this is that the oe 76 LTD plenum has a lot of porosity in and around the fuel transfer port at the top front of the plenum by the anti-backfire valve mounting pad. I thought initially that this was just a freak occurance and then I got a replacement plenum, also a 76 that also has heavy porosity in the same area and lots of fuel staining on the outside of the plenum casting, just in the middle of the transfer port casting boss, no trail.
One other thing that shows that this probably was a leaker is that the plenum seal o’ring in that port appears to have been heavily permatex’d probably due to trying to stop a leak.
So now we’re on the third plenum, also a 76 and it is perfectly smooth with no signs of porosity at all, just perfect. So I’m wondering if this is a chronic casting problem that we’ve blamed for poor installation or a bad seals. So my advice is that if you have a leak that you can’t seem to identify or stop, take a really close look at the plenum for porosity !
Re: 1000 Plenums
:worthless:
Cliff (74yrs ;) )
redglbx
Re: 1000 Plenums
Post by redglbx »
Yep Cliff, totally agree , but I need to get my customer taken care of first and then I think I’ll make a test fixture and some pictures but I only have so many hours available, so I’m gonna have to circle back.
My basic point of all this is that troublesome plenum leaks seem to be a constant problem and then to get 2 in a row that show heavy porosity and evidence of leakage through that porosity ,well I guess I just thought I might save someone the headache that these 76 Ltd carbs have given me. Anyway once I get the customer taken care of I’ll take some pictures of all this,,, patience my friend 🤔😁
pidjones
Re: 1000 Plenums
Post by pidjones »
A great aid in spotting small fuel leaks is a cheap UV flashlight. Gasoline glows bright green under one.
redglbx
Re: 1000 Plenums
Post by redglbx »
Great idea PID ! I forgot about that ! Thankyou.
