Front an rear brakes
Ok so I know there's probably topics already out there but I've tried looking. Anywho so on my 77 I've take the calipers off an apart an cleaned then made sure the seals were ok an what not put them on but for some reason when I press the pedal for the rear or the lever for the front the brakes work but it's like there releasing to fast where I almost have to pump the lever as fast as I can then hold it same with the rear any suggestions or other topics greatly appreciated it.
Re: Front an rear brakes
You are correct that brake subjects have been covered well. Look down below to see just a few topics on them.
Sounds like you still have air trapped in the system. Tie the handle back or try vacuum bleeding from the bottom seem the be the most popular fixes
See all I did was pump a couple times hold it an open the valve a couple times I do have a vacuum bleeder I used on the rear I kept pumping the rear while having vacuum on the caliper till I got fluid out but there must still be air in the rear as well what about gravity bleeding
- 510 Views
Last post by bagger13
- 9 Replies
- 354 Views
Last post by BlueThunder
- 6 Replies
- 273 Views
Last post by Whiskerfish
- 4 Replies
- 262 Views
Last post by bulldozer
- 12 Replies
- 412 Views
Last post by robin1731
