Hi!
I managed to break the circlip that holds the driveshaft "together". I did get it out though
I can't seem to find it on the fiche - maybe it's called something else. Regardless, can someone let me know the size I need and a possible source for replacement.
The bike is a 1980 GL1100.
Thanks!
Driveshaft Circlip Size
- milesoffun
MilesOfFun
80 GL1100 - Yellow (Got wet due to Huricane Sally - gonna give it a try!)
83 GL1100I - Blue (Got wet due to Huricane Sally - but gonna give it a try!)
- ritalz
Re: Driveshaft Circlip Size
https://www.partzilla.com/catalog/honda ... ller-shaft
Item 26 looks like it could be the one 20mm.
- Old Fogey
It's good practice to always renew circlips like that. Internal circlips are not so bad being under comprssion, but external have to stretch quite a bit to fit.
- milesoffun
Sure looks like the one! Thanks for the assistance - just ordered - might should have ordered more! And the link was helpful. Last time I was needing parts Bike Bandit was still around
MilesOfFun
There are two of them on that shaft. the coupler on the other end is held on with one as well. might change them both if you had it apart
I always put in a new one
Mostly because I either bend the poo out of it taking it off, or it shoots a crossed the shop never to be seen again.
Please make sure you use an external circlip. My Hunley build had two internal clips stretched onto it (both ends). It was a real trick getting them off!
I have NEVER done thst
- 16 Replies
- 345 Views
Last post by chewy999
- 27 Replies
- 599 Views
Last post by Sidecar Bob
- 25 Replies
- 891 Views
Last post by gltriker
- 8 Replies
- 604 Views
Last post by sunnbobb
