Is the brake fluid reservoir on a '76 supposed to be completely opaque?
I'm not sure if this is aftermarket, but it is entirely opaque. That isn't a problem in itself, but I am unsure of how far to fill after bleeding. My manual's photo is in black and white and a bit grainy, and I can't tell what upper level mark it is referring to. Any advice is welcome!
1976 GL1000 Sulfur Yellow (bought it dead and got it running. Making it perfect will be my eternal project.)
2000 VFR
2003 Blackbird (sold)
1993 CBR1000F (sold)
1998 Valkyrie (sold)
2002 Concours (sold)
1989 EX500 (sold)
2000 VFR
1989 EX500 (sold)
- BlueThunder
Re: Is the brake fluid reservoir on a '76 supposed to be completely opaque?
Normal color for one that old. New ones are opaque white plastic.
Fill to top ring.
Fill to top ring.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- Lowrider Bud
- Zinc Member
New reservoirs are available, $37 on fleebay. Pretty easy to replace. Then you can see how much is in there.
I fill my '75 reservoir about 2/3 full and it works good. Make sure the handlebars are turned so the reservoir is level when you are filling it.
Later, Bud...
Later, Bud...
Time for another Road Trip...
- Dr. Frankenstein
There's an Upper Level mark...? I don't know any 'specs' on it, but I usually just add it until it doesn't overflow any more...the diaphragm in there tends to push out any excess...
Looks like yours could use a good gentle cleaning, or you can just replace it with one from BrakeCrafters if you want that OEM look:
https://www.brakecrafters.com/collectio ... voir-kit-1
Kind of pricy, but even the OEM ones on eBay are too. I've used those guys for new brake pistons for my '75 and '78 Wings; they're very helpful and returns (if you need to) are no problem.
My money tree died last year, so I replaced the one on my '78 with this from eBay - $23 with shipping included and it works fine; plus I don't have to spend the money on a MC rebuild kit:
https://www.ebay.com/itm/202822503563?c ... gJYrvD_BwE
Also, as long as we're on the subject, if you're going to re-do the master cylinder, these brake cylinder pliers are a Must-Have - they can get down in there to release the snap ring that goes around the shaft; very worth the money.
https://www.ebay.com/itm/234560295900?h ... R9DE2Ou7YQ
I always assumed those rings on the outside were the level marks. Shining a strong flashlight through it might give enough of a shadow to see what's inside, even with that one. Not too hard to open the lid and look in, though.
- Lucien Harpress
As I understand it, the plastic is supposed to be translucent, similar to the coolant overflow tank. The two lines are your upper and lower levels, and you SHOULD be able see your level from the outside.
They turn opaque as they age, which is why they switched to windows later on.
Thanks! Will go to the upper mark. Will plan to replace the reservoir eventually...it'll join the ever-growing of things I'd like to fix on this bike someday.
2000 VFR
1989 EX500 (sold)
2000 VFR
1989 EX500 (sold)
before and after on my 82.
- 36303023_10155692925755817_4738773396341391360_n.jpg (110.13 KiB) Viewed 274 times
- 36369092_10155692926495817_1274465973822291968_n.jpg (132.08 KiB) Viewed 274 times
If everything is as it should be the level in the master cylinder is the easiest way to determine how worn the pads are. The theory is that you should fill the master cylinder to the upper level mark after replacing the pads and bleeding the system and as the pads wear the piston(s) will stick out more so that more of the fluid will be in the caliper and less in the master cylinder and the fluid should be just about at the lower level mark when it is time to replace the pads.
Of course if you don't understand this and top the level up before the pads need to be replaced you a) won't be able to tell what the pads are like by the level and b) could overflow the reservoir if you press the piston(s) back into the caliper(s) for any reason.
I do that with all my vehicles. If the level drops in the reservoir significantly it's time.Sidecar Bob wrote: ↑Sat Jan 28, 2023 7:28 pm If everything is as it should be the level in the master cylinder is the easiest way to determine how worn the pads are. The theory is that you should fill the master cylinder to the upper level mark after replacing the pads and bleeding the system and as the pads wear the piston(s) will stick out more so that more of the fluid will be in the caliper and less in the master cylinder and the fluid should be just about at the lower level mark when it is time to replace the pads.
- 301 Views
Last post by Whiskerfish
- 35 Replies
- 677 Views
Last post by robin1731
- 23 Replies
- 637 Views
Last post by chewy999
- 13 Replies
- 923 Views
Last post by txtriathlete
- 9 Replies
- 1084 Views
Last post by Snapper33
