Back firing into carbs
Re: Back firing into carbs
- 16834173997362397197257703356505.jpg (186.92 KiB) Viewed 481 times
So are you going to swap the heads or change the valves? Nice you now know the cause. Personally I would swap heads as it gets you on the road faster. .
Right well I still have an issues with the left side or 2 an 4. It's off now. An I've taken thebother heads that I have an took those apart an the valves are straight an good just need cleaned up. Do yall think I need to re tap the valves I got valves tapping paste.
Lapping not tapping
If you already have the valves out, then Lapping is a good process to get the compression up and add a bit of power. Worth the effort for sure.
So I lapped all the valves last night the intake valves look great but the exhaust valves I think I might re lap those again. I had a hard time trying to get the lapping tool to stick onto the exhaust valves.
An alternative is to use a short piece of rubber fuel line on the stem side.
- 16841048829017581607301866728331.jpg (170.01 KiB) Viewed 363 times
Head 1 done an holding mineral spirits nothing leaking
Very Good!BurnsYoFace34 wrote: ↑Sun May 14, 2023 6:55 pm Head 1 done an holding mineral spirits nothing leaking
How did you clean up the gasket surface?
Cliff (74yrs )
I took a 2x4 that was longer than the head put a peice of 1000 grit sand paper an wet sanded it up down then rotated to side to side Aplying little pressure an then did the same with the block
Progress. Gasket surface looks happy.
Not questioning your work, Burns. Just need to see where you are.BurnsYoFace34 wrote: ↑Sun May 14, 2023 11:43 pm I took a 2x4 that was longer than the head put a peice of 1000 grit sand paper an wet sanded it up down then rotated to side to side Aplying little pressure an then did the same with the block
Man, we've turned you around!
Cliff (74yrs )
Ahh I know I'm just answering yalls questions. Now I did the other side an it's kinda sorta leaking a lil bit of mineral spirits through the intake valves. But I went ahead an put it on the bike. Should I take it off I did attempt to re seet those intake valves before I put it though but idk
Thinking you may be fine. I have not tried the mineral spirits leak test and think many fine running bikes would leak just a small amount. I suggest going forward but other can freely argue.
- 264 Views
Last post by Whiskerfish
- 3 Replies
- 251 Views
Last post by gltriker
- 319 Views
Last post by chewy999
- 18 Replies
- 460 Views
Last post by millerdog
