Sea Foam for Carburetor Cleaning
Funkdoctor
Zinc Member
Zinc Member
Post by Funkdoctor »
Ford Goff you guys have giving me the gumption to work on my bike myself. I wanted to see if anyone thanks a good idea to drain the floats and then use sea foam. Or If I should just pour it in with gasoline with the recommended 1 or 2 ounces through the tank? It’s been rough idling and running bad. Iowa bike 19k. If you have any good videos links please share.
RIP: cookie
Re: Sea Foam for Carburetor Cleaning
Won't hurt .... just put some in the gas tank and go for a good ride .... the ride will do the most good but the Seafoam won't hurt as long as you don't overdo it ....
flyin900
Post by flyin900 »
As noted it doesn’t hurt to try it and I would dose it heavier than a few ounces and use half a can in the full tank of gas. What it won’t do is clean dirty carbs where the jets are crudded up badly. If that is the case then you will more than likely have to pull and clean/rebuild the set.
Worth trying the Seafoam first and see how that works out for you. If you need the carbs cleaned then there are tutorials on here as a DIY, or there are a member or two that offer these services in the For Sale section here.
Current Bikes:
Earl43P
Post by Earl43P »
https://www.berrymanproducts.com/videos ... nt-test-3/
Too much Seafoam makes your exhaust smoke and smell. Too much B12 just burns and cleans, as designed.
I use 1/2 can of B12 once my petcock hits Reserve. Then I ride 5+ miles at various speeds/rpms. Then I refuel and add the other 1/2 can. I can tell when my Valkyrie needs dosed; idle rpm drops and “hunts” and takes longer cranking to fire up. (That bike often sits for 2-3 weeks while I ride the ST1300). It’s 6 carbs have never been touched in 84,000 miles, but I dose them at least 4 times a year. I ride it all year round.
Based on my usage, my opinion is that you CAN’T overdose B12 and it works great.
I use it in the ST1300 too, just to clean the injectors. I honestly can’t tell much if any difference, but consider it preventive maintenance.
I suggest a heavy B12 dose, ride it a bit, then drain the bowls looking for sediment. Ride it until that heavy dose is done, then continue with a moderate or recommended dose for several tanks. Good luck!
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
pidjones
Post by pidjones »
I use engine chemicals according to manufacture instructions, because I figure they know the best use of their products. I have had to help recover from Seafoam over-use. But then, I'm no chemical engineer. I do find engine chemicals help if used according to instructions.
ob1quixote
Post by ob1quixote »
I like Berrymans B12, but I do not like to leave it in the tank.
It is a very strong solvent and can mess up rubber bits.
Dont spill it on a painted surface!
I suggest running it from a half tank of fuel, running it until almost empty.
Refill the tank with gas and take a short ride to clear the bowls and mix up whatever B12 was left from the cleaning run.
1979 GL1000
2001 DRZ400
1983 CR480
Lucien Harpress
Post by Lucien Harpress »
My boilerplate, personal-experience advice every time somebody brings up Seafoam:
Great product, just be SURE your gas tank is moderately clean.
Because Seafoam does it's job SO well, there's a VERY good chance of it knocking all that interior rust loose, and then your carbs will NEVER be clean.
(Learned that the hard way on my first bike.....)
I agree with Lucien from experience. When I first soaked parts in Berryman’s B12 cleaner, the rubber bits ballooned almost instantly. So I only use it on the metal bits. Having said that, it could actually be helpful in a bike that has sat dry for a period where the rubber has shrunk up, such as carb-to-plenum seals.
It works great to put on a q-tip and clean around carbs for show.
scootsx2
Post by scootsx2 »
Earl43P wrote:https://www.berrymanproducts.com/videos ... nt-test-3/
I have used Berryman's a few times with my Vespa (lumpy idle) and with my CX500-based police trike (firing on one cylinder at startup after filling with apparently crappy gas). It worked as advertised. I generally stay away from fuel system "cleaners" although I do use Stabil Marine on a regular basis since I never know when my bikes may have an extended layup due to work interfering with riding.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Mike-C
Post by Mike-C »
Gents;
I put Seafoam in my tank a couple of times a year, just for 'feel good' purposes. Bikes, cars, tractor etc. Only in gassers, my diesels get Diesel Kleene.
Mike Coleman
'84 Wing-Lite (ex-Aspencade)
'84 (un-Terstate)
Mike Coleman
North Lancaster, Ontario
Canada
