powder coating question
- custom shadow
- My Album: www.custompolishing.freeservers.com
had my gl1200 brake calipers powder coated and the guy got blast in piston chambers is this a bad thing or will they be ok? any help please
Re: powder coating question
Don't know. If it is thick enough it could cause interference problems with the piston. I also don't know if long term exposure to brake fluid would harm the powder. You could use silicone brake fluid to maybe eliminate that.
- Placerville
So, your saying that when the parts were blasted, some of the media got into the piston chambers and did.....what? Is it badly damaged or is there just a small blemish to the wall? Either way, I don't think you're going to know how bad it is until you've reassembled them and at least done a stationary test to see if the piston moves and the pads back off the rotor. The damage is done, the question is, how bad is it?
Placerville wrote:So, your saying that when the parts were blasted, some of the media got into the piston chambers and did.....what? Is it badly damaged or is there just a small blemish to the wall? Either way, I don't think you're going to know how bad it is until you've reassembled them and at least done a stationary test to see if the piston moves and the pads back off the rotor. The damage is done, the question is, how bad is it?
OOPS! I was thinking they got some powdercoat in the piston area. DOH!!!!!!!!
Let me say this. I have used my bead blaster to clean the brake caliper piston area's. But, most/many powder coaters use sand to blast the parts. Which is harsher on the surface. I don't think you'll have any trouble though. As long as like Placerville said they didn't get carried away.
- custom shadow
thanks guys. i should have explained a little better he did get blast in the chambers and instead of the smooth and polished bore it is like 1000 grit wet/dry sandpaper
custom shadow wrote:thanks guys. i should have explained a little better he did get blast in the chambers and instead of the smooth and polished bore it is like 1000 grit wet/dry sandpaper
Yeah, I think it will be fine. Like I said I sometimes do mine with the bead blaster.
- fish
put the pistons in there dry and with out the seals...
See if they slide smoothly in the bores
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
run a fine emery cloth around the inside and you should be fine.
- tomk1960
I always tape over the bores of master cylinders and calipers, and I put bolts in the bleeder and banjo bolt holes before I blast them with aluminum oxide. It's too bad that he was careless and blasted the bore, but I think you'll be ok. With no seal in a clean caliper, the piston will "drop" right into the bore with no real friction. The fit isn't very tight and the rubber seal is what's doing all the work during piston travel. If you wanted, you could put a 3-stone brake cylinder hone in your drill press and just clean up the bore - it would only take a few minutes. Use a little brake fluid for cutting as you run the hone up and down.
In any event, blow out the holes with compressed air, rinse them out with hot water, and then blow them out again to make sure you got all the grit out. Then you'll be good to go.
Were the threaded holes blocked off, or is there a powder coating on the threads?
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
- custom shadow
I used a little wire wheel on a dremel to clean out the grooves where the seals go and then i used 600 wettomk1960 wrote:I always tape over the bores of master cylinders and calipers, and I put bolts in the bleeder and banjo bolt holes before I blast them with aluminum oxide. It's too bad that he was careless and blasted the bore, but I think you'll be ok. With no seal in a clean caliper, the piston will "drop" right into the bore with no real friction. The fit isn't very tight and the rubber seal is what's doing all the work during piston travel. If you wanted, you could put a 3-stone brake cylinder hone in your drill press and just clean up the bore - it would only take a few minutes. Use a little brake fluid for cutting as you run the hone up and down.
dry paper on the bores but even without seals i dont think they will "DROP" in
- SANY3832.JPG (54.63 KiB) Viewed 316 times
- tomk1960
Well maybe "drop" was too strong a word. The pistons should slide in quite easily - let's put it that way.
Is that powder coating I see on the threads of the banjo fitting holes?
1978 Honda GL1000
1978 Honda GL1000
- custom shadow
yeah i tapped the bleader holes i have to do the banjo fitting holestomk1960 wrote:Well maybe "drop" was too strong a word. The pistons should slide in quite easily - let's put it that way.
Is that powder coating I see the threads of the banjo fitting holes?
I have smoothed up the inside of mine with some 1000 grit. but time will tell....
they sure look nice
they sure look nice
- 16 Replies
- 686 Views
Last post by ianstaley
- 26 Replies
- 767 Views
Last post by taunusrainer
- 85 Replies
- 7400 Views
Last post by mhynze
