Has anybody used these for 75-77 GL1000s from SCI and if so how is the quality? Do they look like the OEM ones? They do in the picture but sometimes pictures look different than the real item. If I can find ones that look original and are the same form/fit/function as OEM I'd like to use them. SCI tells me they come out of a Europe supplier. At first I thought they were Emgo but they aren"t.
BRAKE:
http://www.siriusconinc.com/pro-detail. ... _id=122608
CLUTCH:
https://www.siriusconinc.com/pro-detail ... ct_id=3307
GL1000 Replacement Brake and Clutch Levers from SCI
- SCI Brake Lever.jpg (35.6 KiB) Viewed 242 times
- SCI Clutch Lever.jpg (42.11 KiB) Viewed 242 times
2001 GL1800 Illusion Red
Re: GL1000 Replacement Brake and Clutch Levers from SCI
I don't know about that particular part but I have been pleased with other stuff I have bought from SCI.
Thanks Whiskerfish, I was getting ready to order some brake hoses from SCI and noticed these and thought I would ask the forum about them.
- flyin900
I bought the GL1000 brake hose kit from them the three front hoses and the special rear one that is part rubber hose and part formed metal hose. The quality was like OEM and the metal fittings for the banjo bolts are anodized to resist corrosion.
Current Bikes:
Thanks flyin900. I decided I will try the levers and will order them when I order the brake hose set.
- BlueThunder
Are the levers 8" or 7"? Stock ones are 8".
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Good question but the SCI site doesn't give a size, just that it replaces the part number.
- 6 Replies
- 515 Views
Last post by Kool_Biker
- 2 Replies
- 576 Views
Last post by majorweakness
- 4 Replies
- 174 Views
Last post by rnelson
- 12 Replies
- 479 Views
Last post by Sidecar Bob
