Engine painting
- dritzman
Engine painting
I'm working on a new project. Let's just say that it's a 70's inline 4. I'm going to paint the motor and have never done it before. I've read so many differing opinions on what type of paint to use. What type of primer to use. To rattle or not rattle. I think my head might implode. Any recommendations out there of luck/no luck? Any help is appreciated.
"Sometimes you have to go up really high to understand how small you are".... Felix Baumgartner (Red Bull Stratos jumper)
1978 GL1000
1995 CBR 900RR
2006 GSXR 750
1978 GL1000
1995 CBR 900RR
2006 GSXR 750
- RIP: cookie
Re: Engine painting
Most use Duplicolor .... see threads at the bottom of the page ....
- brianinpa
Re: Engine painting
VHT is another option. The "Cast Aluminum" is pretty close to original color and I haven't had any problems with it fading, pealing, or flaking off.
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
Re: Engine painting
VHT is also good. I have used both. VHT especially on headers, and exhaust
- Lucien Harpress
Re: Engine painting
I got a spray can of some Duplicolor engine Aluminum (I don't think I used the Cast Aluminum, just the regular stuff) from a local auto parts store for my KZ1300 motor. I got the block as clean as I could, but didn't really sweat the small stuff- it was already pretty good to begin with, and in my opinion if the stuff won't come off with a hard scrubbing, it wasn't going to come off under normal use either.
I may have bothered with primer on this as well, just to give it a bit of help. Both primer and paint sprayed really easily, and once you get a heat cycle or two through the motor, it's actually been pretty resilient. I've got no complaints with it.
- mcgovern61
Re: Engine painting
I used the Duplicolor 1615 with high heat clear and it looked great! Later on, I changed to Duplicolor Iron with the high heat clear again and it is holding up great!
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
Re: Engine painting
mcgovern61 wrote:I used the Duplicolor 1615 with high heat clear and it looked great! Later on, I changed to Duplicolor Iron with the high heat clear again and it is holding up great!
SNIP
Looks awesome. How long ago did you do this?? I tried the clear on some stuff but found with age it turned a bit amber colored and did not care for it.
- mcgovern61
Re: Engine painting
I painted with the 1615 in March 2008 with the clear and it stayed looking new right up until I changed the color to Iron with high heat clear in May of 2014. The Iron color and high heat clear still look new!
Gerry
Re: Engine painting
Thanks
- propav8r
Re: Engine painting
I used a Rustoleum engine enamel product. The only issues I have are self-inflicted with lazy prep. It's held up pretty well considering.
- rudolphwolven
Re: Engine painting
Engine:
- 1) VHT Engine light primer...................Art.nr: SP-148 (2 Pcs. Spraycan 400 ml)
- 2) VHT Engine universal aluminium......Art.nr: SP-127 (2,5 Pcs. Spraycan 400 ml)
- 3) 2 Component-(gloss)clearcoating from: AUTO-K-Spraymax 2K Klarlack Hochglanz (incl. Härter) Sprühdose 400ml........Art.nr: 680061 (3 Pcs. "two in one"-spraycan 400 ml.) (better resistant against petrol and oil)
Very nice,glossy and "hard" total result !
COLOUR IN OUTSIDE DAYLIGHT
COLOUR WITH ELECTR. LIGHT INSIDE
Proud winner of the NGWClub-USA contest Bike of the Year 2016------ GL1000 K1 1975
- rudolphwolven
Re: Engine painting
Thank you sir..............!
Re: Engine painting
dang that is sweet!
Re: Engine painting
Nice. I like Duplicolor, and Rustoleum. But on HOT stuff I use vht.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
- 303 Views
Last post by Pony Ruiz
- 596 Views
Last post by Goboy
- 19 Replies
- 858 Views
Last post by redglbx
- 4 Replies
- 383 Views
Last post by Sidecar Bob
