Epoxy marine paint
Epoxy marine paint
I do lots of brush painting, i have always wanted to brush a frame. I have never seen any paint go on like this oil base marine epoxy. I am convinced I could paint a frame with no brush stroke.
- 20180620_115853.jpg (79.81 KiB) Viewed 322 times
- 20180619_065102.jpg (142.43 KiB) Viewed 322 times
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
Re: Epoxy marine paint
My Wife is a semi retired house painter. She can paint trim and make it look like glass. I don't see why it could not be done on a bike frame. I think the consistency and flow mixing of the paint is one of the most critical parts to help any brush strokes lay down.
For interior trim paint I think it down, not always exact but close, use a small low nap roller to get the paint on quickly and try to run a brush as fast as possible the least amount of times and walk away..the thin lines settle perfect(most the time;)..) I could not do it on a frame I think. I'd love to see it if you do it!!
78 gl1000 rat project thingy...still under construction
76 gl1000 parts for 78? Trying to get running...
- duke182
Give it a try.
Then good or bad post the results.
I for one would love to see it either way.
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- Rusty Probie
https://www.sheldonbrown.com/paint-prep.html
Marine grade epoxy you mix yourself. You could control how it "self levels".
Marine epoxy enamel -- primer and topcoat -- can be purchased at boating supply stores. It largely avoids the drying issue, because it has two components which you mix together like epoxy glue. Most hardening occurs within a few hours through a chemical reaction.
Check out the CB750 sohc site. One guy brushed his tank with rustoleum with good results.
http://forums.sohc4.net/index.php?topic=52336.0
I say go for it and post your results.
- 17 Replies
- 5563 Views
Last post by Sidecar Bob
- 1 Replies
- 130 Views
Last post by redglbx
- 4 Replies
- 5846 Views
Last post by japcrap
