Making a naked bike out of a bagger???
BarnRat
Post by BarnRat »
Is it feasible to buy an old Aspencade (or the like) and remove all the bags and tupperware to create a naked GoldWing? Or is there too much ugliness (wiring and such) under the plastic and too much that would have to re-added to make the bike look presentable? Is it possible to put a normal set of handlebars on a de-nuded GoldWing, replacing those huge swept-back bars? I guess the instrument cluster, headlight, turn signals would be another PITA?
Stop continental drift!
FrontRunner
Re: Making a naked bike out of a bagger???
Post by FrontRunner »
As I understand it, people have done it. It's not as easy as starting with a bike that didn't come dressed out by the factory but it has been done. What year of Aspencade are you working with?
1978 GL1000 My 1st GL Learning experience
2000 Kawasaki Nomad 1500
BarnRat
Post by BarnRat »
I just used the Aspencade as an example. I assume the difficulty would differ depending on which tupperware/bagger model I started with. I really don't care much about the final looks -- I would just consider it my "rat bike" and go with it. To strip a bagger is not my first choice, but there are a lot of old baggers out there.
Lucien Harpress
Post by Lucien Harpress »
1000- Pretty easy for all of them.
1100- From what I remember, it's pretty easy to do on any of them except for the 83 Aspencade. It came with a large digital instrument cluster, a LOT of options, and all the associated wiring. Still doable, but a PITA.
1200- Look for a Standard, or look for a LOT of work.
1500 and up- You're a madman.
BarnRat
Post by BarnRat »
Thanks. It's just a thought -- maybe not a good thought. I'm patient so I'll probably just wait till a real naked GW comes along. They pop up a couple of times a month on Craigslist.
The 1100's (except the Aspy, as mentioned above) are very easy to go naked. All the fairing and bag wiring are sub - harnesses, and just unplug. If you're not concerned with 100% original, a set of aftermarket turn signals, headlight bucket, and brackets are about all you'll need. The bars are typical 7/8 inch diameter, so just about any 'metric' bars will work. Cable lengths can be an issue if you go really low, but there are options. Good luck with your search!
desertrefugee
Post by desertrefugee »
Yep, if I was in your shoes, I'd be looking for a 1000 or an 1100 (non-Aspy). They're common as heck and will save a lot of aggravation.
desertrefugee
desertrefugee
Don't know how picky you are, but there are choices here in AZ if you drive a bit. (Lots in Phoenix).
South of you:
https://tucson.craigslist.org/mcy/d/197 ... 17936.html
Lucien Harpress
Pretty much everything they said. If you stay in the GL1000-1100 range (and stay away from the 83 Aspencade), it's no more difficult to strip one down than it is any bike with bags and a fairing.
TNTbefree
Post by TNTbefree »
It takes a bit of work, but it can be a lot of fun. What was said above is true... This is the before and after of my 81 interstate...
Before:
1981 Goldwing GL1100 01.jpg (110.89 KiB) Viewed 283 times
After:
army od green naked 1981 goldwing gl1100 04.jpg (80.04 KiB) Viewed 283 times
BarnRat
Post by BarnRat »
TNTbefree wrote:It takes a bit of work, but it can be a lot of fun. What was said above is true... This is the before and after of my 81 interstate...
Nice work! action1
BarnRat
Post by BarnRat »
Thanks to all for the suggestions. I've made notes of them. :2thumbs
I wouldn’t rule out a 1200. If you don’t mind adding your own gauges (cheap) and adapting an 1000 or 1100 tank shelter, the wiring isn’t daunting. Except for the stator issues, it was pretty bullet-proof. Nice rims, ability to adapt 1500 parts and use a car tire.
BarnRat
Post by BarnRat »
Thanks! anim-cheers1
