anyone a fan of red kote?
cbrianroll
Post by cbrianroll »
Seems good as far as I can tell, anything bad has been installer error or bad patch. Anyone here have good pr bad to say about it? Thanks.
78 gl1000 rat project thingy...still under construction
76 gl1000 parts for 78? Trying to get running...
Re: anyone a fan of red kote?
Was a fan but not anymore. Bout 8-10 years ago I took a gas tank to a rad shop. they cleaned and coated with red kote. Paid a bunch of money. this past year my reserve quit working and I looked inside. the entire coating had failed. Looked like probably a half inch of blackish powder in the bottom of the tank. Luckily i had a really good filter. Not sure what caused it but I will never use it again.
cbrianroll
Yikes! That's not awesome....my tank is great on the inside, but a bit flakey around the emblems, thought maybe a extra barrier would be a good idea, maybe not.
LuckyEddie
Post by LuckyEddie »
That's all I've used, 4 times so far. No issues. My oldest application is 12 years ago and holding up fine.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
cbrianroll
Interesting...perhaps preparation was different. I guess I would t know until I knock the rust off. I'm prob going to need to weld a new petcock in so maybe just weld/solder any holes I find.
Yea no idea why it failed. Maybe the product used was old or may have been prep or something else
This is what my filter looked like, it was packed in there.
and this is what I flushed out of the tank
cbrianroll
Wow....nasty
digschopper
Post by digschopper »
I use kreem. No issues,and being white,you can inspect the tank easier.
I also like Kreem. Still working after 15+ years
cbrianroll
Is there a 3rd brand often used? Seems there was but I can't remember what....
cbrianroll
Oh duh....por15...
Post by HOTT »
I've had my best luck with just using POR-15 paint. Pour it in, slurry it around.
Impervious to fuel, made to work with rust. Ideal when welding a tank.
They make a tank sealer too, have never used it. I'm guessing it's probably pretty good too.
lcallison
Post by lcallison »
Another product is Caswell. I've used it a couple times and it worked well. I don't know how long it lasted though as I no longer have either bike.
Larry
84 GL1200A
79 GL1000
duke182
My Album: http://ngwclub.com/gallery/v/wingmans/duke182/
Post by duke182 »
Red coat vapors are rough.
Make sure to ventilated well.
Only problem I ever had with red coat; it turned my gas red when I didn't let it fully cure before filling the tank.
It eventually cured and offered no other problems.
But
I like por15 better.
1984 1200 standard
click pic to see my gallery
vote in my poll
I believe red-kote is dissolvable with acetone
