ditto, that is how I use mine.... it also has an air guageritalz wrote:+1 on the small 12 volt unit. I also snip the ends and attach some clips to attach directly to the battery. That keeps from messing with any fused circuits because these things can draw lots of power.
12 Volt Air Compressor
Re: 12 Volt Air Compressor
- Solina Dave
Rodger,rcmatt007 wrote:ditto, that is how I use mine.... it also has an air guageritalz wrote:+1 on the small 12 volt unit. I also snip the ends and attach some clips to attach directly to the battery. That keeps from messing with any fused circuits because these things can draw lots of power.
I also agree with Al on avoiding fused circuits, and going straight on the battery.
But what model compressor do you have, if its got a gauge? I don't think the Slime 40001 Mini Compressor has one.
........Dave
"ASSUME NOTHING"
1st motorcycle-1977 Honda CB550F Super Sport
2nd motorcycle-1978 GL1000
"Not riding a motorcycle is wrong"
- ritalz
I don't have ant info on the brand. Purchased at Harbor Freight. They are available at many other outlets, just find one suitable for vehicle tires.
- Solina Dave
Sorry Al. I thought you were referring to the Slime 40001 compressor.
Dave
Dave
"ASSUME NOTHING"
I am not sure who made ours
- Solina Dave
Some smaller compressors I've been seeing have a nozzle that screws straight on to the valve stem. It looks like it might be difficult, to maybe impossible to apply it to the valve stem on a wheel such as the Comstar on my '78. The Slime 40001 Mini compressor has a right angle, clamp-on nozzle that looks like it would fit better. However the 40001 doesn't have a gauge. Does anyone who uses this particular compressor find it to be a pain, stopping the compressor, removing the nozzle, taking a reading, then having to put it all back together, until you finally get the pressure right? Although I suppose you could overfill the tire, and then bring the pressure down manually to wear you want it.
Never thought of that!! .................. ...Dave
"ASSUME NOTHING"
the ones without a gauge are a pain.... pump it up until it explodes then let some air out
- chewy999
To be honest I wouldn't worry about a gauge on the compressor. I have a 240v compressor with a gauge which is great but I still check the pressure manually with an accurate gauge.
Back in the day when I was in the Air Force, we had a piece of kit that we could check our gauges on. I tested two brand new pencil gauges on it, at around 32 psi, one was 2 psi under and the other was about 8psi out!
Just saying.
Just saying.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- Solina Dave
Ha!.....You think that's funny!!rcmatt007 wrote:.... pump it up until it explodes then let some air out
"ASSUME NOTHING"
It is kind of a pain, but it works for me. I do usually over fill it a bit, then make adjustments. It's not like the compressor is super fast, lol...
- Solina Dave
Yeah! But you know, you can never be too safe!Track T 2411 wrote:It is kind of a pain, but it works for me. I do usually over fill it a bit, then make adjustments. It's not like the compressor is super fast, lol...
"ASSUME NOTHING"
I think grass grows fasterTrack T 2411 wrote:It is kind of a pain, but it works for me. I do usually over fill it a bit, then make adjustments. It's not like the compressor is super fast, lol...
Why don't you add a shutoff valve to your 120V compressor so it will hold its pressure?
