Shinko Wear Bars????
Solina Dave
Post by Solina Dave »
I've put 3600 kms. on my Shinko 230 Tour Master tires. I'm very pleased with their performance.
However I can't, for the life of me, locate the wear bars. There's a locating arrow on the sidewall, but after a close inspection, I don't see the bars.
Any chance that anyone else has encountered the same? I believe that some tire manufacturers don't apply a wear bar to their tires. But I'm sure their numbers are minimal.
Or maybe I'm just going blind! There's always that! lolol
Thanks......... anim-cheers1 ...Dave
"ASSUME NOTHING"
1st motorcycle-1977 Honda CB550F Super Sport
2nd motorcycle-1978 GL1000
"Not riding a motorcycle is wrong"
5speed
Re: Shinko Wear Bars????
Post by 5speed »
Are the holes in the center of the tire as deep as the grooves? Those may be the wear indicators.
Solina Dave
5speed wrote:Are the holes in the center of the tire as deep as the grooves? Those may be the wear indicators.
I think you might be right regarding the depth of the holes next to the centre line. On the rear tire, there's a 2/32" difference in their depths, the hole of course being shallower of the two. I don't really think I'd want to let the tire get quite that worn. But it should definitely be a wakeup call for anyone at that point, I would hope.
The front tire shows no difference between the indents adjacent to the centre line, and the centre line itself.
And I still don't see a visible standard wear bar on the front, or on rear tires at all. Maybe I am blind! lolol
Another question I have regarding both tires is; If there are no wear bars,then what's the point of the locator arrows on the sidewall?
I sent a request for clarification to Shinko. I'll let you know what they say, if they get back to me.
anim-cheers1 .......Dave............Here's some pictures to look at:
Shinko 230 Tour Master (front closeup).jpg (11.77 KiB) Viewed 300 times
Shinko 230 Tour Master (rear closeup).jpg (16.18 KiB) Viewed 300 times
"ASSUME NOTHING"
Wear bars have nothing to do with the directional arrows. :-?
Oldewing
Secretary
Secretary
Post by Oldewing »
Shinko's are cheap as chips.... if you don't like the tread remaining...........new shoes are in order.
Solina Dave
robin1731 wrote:Wear bars have nothing to do with the directional arrows. :-?
I'm not talking about the directional arrows regarding tire rotation. I'm talking about the arrows on the sidewall that are supposedly pointing to the wear bar location.
"ASSUME NOTHING"
Solina Dave
Oldewing wrote:Shinko's are cheap as chips.... if you don't like the tread remaining...........new shoes are in order.
Thank you.
"ASSUME NOTHING"
5speed
Post by 5speed »
are they pointing to the holes on the outer edge of the tire?
Sidecar Bob
Post by Sidecar Bob »
The Tread Wear Indicators ("wear bars") on most tires are indicated by little arrows, sometimes actually labelled "TWI". The indicators are pretty shallow (1.5mm) and some have tapered ends so that they are next to impossible to see with the naked eye until the tire reaches its wear limit. And some aren't on the centreline.
If you can't see them you could try measuring the tread depth at or near where the arrows point and again between the arrows and see if there is a difference.
