unique front suspension
anyone know how it works?
it looks like the front "fender" is connected to that wishbone with the mono shock on it.
- 46998199_2109562639094046_6838174060828950528_o.jpg (161.32 KiB) Viewed 278 times
- 47065839_2109562612427382_1896092048159670272_o.jpg (183.35 KiB) Viewed 278 times
- x01660
Re: unique front suspension
But it doesn't look like the forks are connected to the fender....
Maybe the setup is similar to shock absorber/strut and spring setup in a car?
Very interesting. Good share.
Edit: if the forks and fender are connected, maybe its a split system, with the main shock at the wishbone doing most of the heavy lifting, and the tiny shocks up top (like the old harleys had) work to dampen the steering?
-x01660
"The best motorcycle is the one well ridden"
"The individual has always had to struggle to keep from being overwhelmed by the tribe. If you try it, you will be lonely often, and sometimes frightened. But no price is too high to pay for the privilege of owning yourself." ~Friedrich Nietzsche
that sort of looks like a modification of the earles type fork
It was profiled in Rednax’s recent link to front ends. I think I read it was very good at speed.
whenever I see a rear end like that I always think "wedgy"
- sgwilly
That's a stock BMW suspension setup from the mid-90's. You can see it better here with it's frame mounted pivot point. I remember seeing these when they came out and going "Whaaaa???" I'm guessing it reduced flex in the forks. They eventually moved away from it and returned to a more conventional set up. Maybe folks just didn't like the look of it. It is quite different.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- Sugs
BMW Telelever. Been around for a long time on their bikes. Still in use on some current models.
_______________________
'79 Honda GL1000 Goldwing
Its good but...and its a big but. Theres no dive, which is fine if you know that which I didnt when i rode one and midway through a corner when i needed a little more steering I gave it a front dab, expecting dive and therefore quicker steering but the bugger stood up and went straight on. Lucky it was an empty road
https://www.motorcyclistonline.com/conv ... awing-line
States:
“What surprised me as I drew up schematic illustrations of the Telelever at different points in its travel was just how much the rake angle and trail changed as the wheel moved through its 4.7 inches of travel: Rake increases about 5 degrees, and the gain in trail is close to 1.2 inches. In percentage terms, rake increases 20 percent and trail increases by 35 percent! Averaged over the length of the stroke,
States:
- calif wingnut
It was their first venture into the cruiser market. I have the brochure here somewhere.
https://www.cycletrader.com/listing/199 ... 5005021861
