Do you maintain and repair your own motorcycles?
Re: Do you maintain and repair your own motorcycles?
I guess I've been using tubes long enough now to be used to them because I rarely pinch one anymore. I think the trick is using proper bead lube so you don't have to wrestle with the levers and inspecting all the way around to make sure the tube isn't between the bead and the rim before you start inflating it.
As for wives, I've only ever had one and we've been married for almost 43 years. There was a time when we might have gone our separate ways but we were both too stubborn so we're still together. I think the biggest breakthrough that contributed to us staying together was when she learned not to keep everyone waiting if I was late coming for dinner (because I was in the middle of something in the shop and couldn't stop right now or if I was talking to one of the neighbours or something) and that I would accept that it was my own fault and eat mine cold after everyone else was finished and without complaint.
I have been in the opposite position I had not used tubes for a long time until we got Beth's Heritage Softail
- chewy999
I rarely use a tube for a motorbike, but if I do, I just use washing up liquid on the bead as lube. I also inflate the tube slightly to make sure it's in the right place and not twisted. Then deflate and fit the beads. They shouldn't take that much force in my experience.
I did learn a very important lesson years ago when fixing a puncture. I was meeting my girlfriend but had a puncture on my bike. So wheel off, patch fitted and reassembled. Still had a puncture!!!!! Wheel off, tube in water, patch applied, reassembled. STILL had a puncture. Long story short, this went on a couple more times and I was down to my last patch. Almost in tears and getting desperate, I asked my dad if he had any ideas.
He took his glasses off, looked at me in a condescending way that only people who wear glasses can, and said..............
'Have you checked the tyre (tire) to see if the cause of the initial puncture is still there?'
Guess what? Yes it was, a nice long and sharp thorn.
From that day I have marked the tyre at the valve so when I find the puncture on the tube, it is easy to see where the tyre was penetrated. May seem obvious, but............
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
The tires I use on the sidecar outfits all require tubes so I don't have a lot of choice.
Re "From that day I have marked the tyre at the valve": Because of the places where each layer's ends are overlapped during production, no tire is perfectly balanced. They usually come from the factory with a balance dot or mark that is supposed to go next to the valve stem on installation to minimize the need for balance weights. Whenever a tire is removed and re-installed (or even saved for future emergency use) the same part should be at the valve to maintain balance so if the original mark is no longer visible the tire should be marked, whether you need to look for the cause of a puncture or not.
Using dish washing or laundry detergent to lubricate tire beads on aluminum rims is a recipe for disaster as Howard Halasz (tech contributor for Wing World Magazine) says in this article on Randakk's site http://www.randakksblog.com/easy-method ... #more-1132
When I used dish detergent to mount tires I always had to remove the corrosion from the inside of the rim with a wire brush but since I changed to using proper bead lube there is hardly any (including on Eccles that is driven on salted winter roads). Also (& this alone is worth the extra cost) detergent seems to almost glue the rubber to the rim but proper bead lube doesn't so it is much easier to break the bead when bead lube was used during installation.
- Lucien Harpress
To answer the question truthfully (I think I added some snark on page 1- I forget), the only thing I haven't done myself is replacing tires- and even then, I take the rim off (and put it back on) myself. Mostly this is for financial reasons- I mean, I could only afford a bike in the first place if it was less than $1500. Paying someone to fix it is out of the question.
The second reason, especially with my KZ1300, is that simply nobody near me has even SEEN this bike, much less know how to work on it. Carburetors are generally my bane, and I still don't know much about them, but the 1300 in particular has forced me to actually learn what's going wrong with something, rather than just throw money at replacement parts until something works.
Now, to be fair I HAVE enlisted the help of a couple of forum members before, but it's usually been for one-off jobs or advice, not long-term maintenance.
- ritalz
A trick I learned some time ago about mounting tires with tubes. Put the tube in the tire and inflate just enough to take shape. Take several large zip ties and close the bead in at least six places. Lube the beads and work them both on the rim at the same time. Line everything up, remove the zip ties and inflate. There are videos floating around showing the process.
That sounds awfully complicated to me....
- ritalz
Not really. A quick search found this video.
https://video.search.yahoo.com/search/v ... ction=view
Ah, that makes sense. The zip ties are there to keep the beads together so you can lever both beads on at the same time. For the tires I use it would take a lot of effort to lever both beads on together, though and all of my rims are aluminum so I'll continue using proper bead lube and doing one bead at a time.
- ancientdad
Yes, I've seen the video and the idea is a good one. Half the battle with getting a tire back on the rim is keeping it in the low section of the rim while working your way around the tire to take full advantage of the "extra" distance that provides for getting the tire over the rim on the opposite side of the section already on (actually, it does sound complicated...)
'73 CL450K5 brat
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
(2) '73 CB750K3, '78 CB750K8/F2
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
I work on my own bikes. Not always because of money. But because of the sense of pride. Especially an older bike Like my 86 Shadow and the 83 GL1100 that I am doing now. When people look at it and ask who did everything....make me feel good to say that I did. My friend has a 2016 Goldwing. I would take mine over his any day of the week.
- Mike-C
Good Day Folks;
Yes, WM, I work on mine not only because I save money, but I really enjoy it. The satisfaction of knowing that you did it yourself and the knowledge that if any other glitches occur you can deal with it.
Mike Coleman
'84 Wing-Lite (ex-Aspencade)
'84 (un-Terstate)
'96 Kawasaki Vulcan 1500 (The Vulcanator)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
North Lancaster, Ontario
Canada
Canada
- ancientdad
Yes, there's not much in this world that's better than the feeling of pride when you answer the question of who did all the work... but for me, it's also about money. If I didn't do virtually everything myself, I wouldn't even be close to being able to afford it. Not to mention, you're not out on the highway riding along, wondering if what the other guy did will be reliable...
'73 CL450K5 brat
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
No, but you're on the highway wondering if what YOU did will be reliable...ancientdad wrote:Yes, there's not much in this world that's better than the feeling of pride when you answer the question of who did all the work... but for me, it's also about money. If I didn't do virtually everything myself, I wouldn't even be close to being able to afford it. Not to mention, you're not out on the highway riding along, wondering if what the other guy did will be reliable...
Long stretches of open road allow my mind to wander over lots of recent maintenance actions. Sometimes i worry about it, sometimes i dont.
- x01660
Especially when you're out in the middle of nowhere with no cell phone reception and rapidly approaching inclement weather...desertrefugee wrote:No, but you're on the highway wondering if what YOU did will be reliable...ancientdad wrote:Yes, there's not much in this world that's better than the feeling of pride when you answer the question of who did all the work... but for me, it's also about money. If I didn't do virtually everything myself, I wouldn't even be close to being able to afford it. Not to mention, you're not out on the highway riding along, wondering if what the other guy did will be reliable...
-x01660
"The best motorcycle is the one well ridden"
"The individual has always had to struggle to keep from being overwhelmed by the tribe. If you try it, you will be lonely often, and sometimes frightened. But no price is too high to pay for the privilege of owning yourself." ~Friedrich Nietzsche
- 12 Replies
- 1060 Views
Last post by 507Derek
- 6 Replies
- 641 Views
Last post by BikeMaine
- 10 Replies
- 464 Views
Last post by 77Gowing
- 38 Replies
- 3034 Views
Last post by wingrider
- 6 Replies
- 973 Views
Last post by Sidecar Bob
