and so a MC question
You can just say "I know" if you know what this lever (relocated) is for.... or post you best guess
here is the full motor
on this motorcycle-Rodger-
- Lucien Harpress
Re: and so a MC question
I'll be the first person to be 100% honest- I had difficulty even finding a lever in the first place.
Um, I mean, ah- "I DON'T know".
I only know because the owner told me.... but then it was obvious
does it lock the steering?
nope
clue.... the wooden plug in the full engine shot
starting handle?
Addicted to Honda's
Addicted to Honda's
does it have something to do with crank starting the engine?
very very close! it does what when you start it?
Cylinder compression reducer device.
Cliff (74yrs )
disengages the transmission? remote clutch?rcmatt007 wrote:very very close! it does what when you start it?
- Lucien Harpress
I'm guessing some sort of compression release also.
After doing some more research, in a Wikipedia article I found a straight on photo of this JAP Engine, installed in a 1934 Morgan. The wooden plug was removed. I reckon for insertion of a starter crank handle? Your clue is cryptic.
https://en.wikipedia.org/wiki/JA_Prestw ... ar_engines
I'm most likely overthinking this.....
But, I also noted the ignition magneto assembly is located in a similar position, to the right of the mystery plug.
I'm thinking, now, the mystery lever controls the advance and retard of the Engine magneto ignition timing via that mystery lever and the external cable attached on the right edge of the magneto assembly.
Yes? No?
Yes? No?
Cliff (74yrs )
YES releases the compression... problem was the crank was on the primary with a two to one and if it misfires you might break a gear
Sooo the starting crank handle, when fully inserted into that "uncorked" hole, also has a hub that reduces compression on that one cylinder by interfering with a cam lobe follower's contact with its respective camshaft lobe?rcmatt007 wrote:YES releases the compression... problem was the crank was on the primary with a two to one and if it misfires you might break a gear
edit: Looking at this system again, apparently the cable assembly disappearing into the top center of the engine, somehow interferes with, at least, 2 camshaft followers' activities?
It also appears that the external front mounted magneto assembly has an external cable attached to control the Engine ignition timing advance/retard function?
Now...... a search for the internal details of that cylinder compression reduction system must be discovered, too!
Cliff (74yrs )
I remember kicking over a BSA 441 Victor when my father brought it home on a trailer.
Still have the BSA 441.
Still have the trailer.
Still have the crease in the fender when it sent me over the bars.
Pretty sure he giggled...
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- 250 Views
Last post by Explorer
- 6 Replies
- 306 Views
Last post by Dog Boy
- 261 Views
Last post by Steevensi
- 22 Replies
- 1317 Views
Last post by hatchward
- 145 Views
Last post by John Schmidt
