Metal cutting chop saw blade questions
I recently picked up a free 10 inch miter saw with the intention of 'converting' it for use as a metal cutting chop saw. I've used both the abrasive and the 'toothed' style blades a few times in the past, and am wondering if anyone with more extensive experience might have any insights or pointers to share. I would typically be using the saw for square tubing, L-channel, etc. Which blade would be better?
- Lucien Harpress
Re: Metal cutting chop saw blade questions
I can't speak for what's "better", mostly because my chop saw experience is limited to the year I worked at a sign shop, and I only used the abrasive type. That being said, given the choice I would lean towards the abrasive kind anyway. I don't like the idea of a tooth catching the metal at high speed, even IF you're clamping the metal down like you should.
The opposite result, of course, being the possibility of a high-speed detonation of an abrasive wheel, which is also not good. But PPE is kind of expected around a chop saw, so the trade-off (for me) is pieces of flying cutoff wheel vs pieces of flying metal and equipment.
But I'll wait for experts to chime in who use it more than I did.
Saw a surface grinder stone blow up once. That was quite spectacular and scary!! Sorry no experience using a chop saw. In the metal shop I played around in we had Vertical and Horizontal band saws for most of our cuts.
I've only seen the toothed blades used at very slow speeds. With cutting fluid for cooling. That would not work with a regular miter saw. So abrasive, I believe, is the only way you could go on a "converted" saw.
But I would check the saw speed as compared to the recommended blade speed also.
- Liam
I have a purpose built circular saw for cutting metals. It has a blade for cutting aluminium fitted and it gives a nice cut. It will cut steel but it would mean using a different blade. The blade speed is slower than a wood cutting saw. I also have a makita compound mitre saw for wood, and although they are available I would not dream of putting a metal disc of any kind into it to cut metal. Angle grinders larger than 4" scare the heck out of me anyway and I avoid using them. This is since a neighbour of mine lost his life tragically a number of years ago after removing a guard from an angle grinder and fitted a larger disc which I can only suppose for economic reasons. Blade disintegrated and a large piece hit him in the abdomen. I do have a horizontal bandsaw in the workshop which I use for cutting so I suppose I am spoiled. Watch the speeds of any blades you use. Using a blade in a tool rated for a higher speed is a lethal combination, as the centrifugal force could cause the blade to disintegrate under load. Whatever you do, be careful.
make sure there is no plastic bits as you will throw off a LOT of sparks.... having used a chop saw to cut metal (with abrasive blade) when I was younger and dumber
Thanks for the replies. Having done a bit more research, I realize I need to do more research, lol! I didn't realize there was such a difference in RPM between a wood cutting miter saw and a metal cutting chop saw. On a side note, there are some really crazy home made tools out there!
Track T 2411 wrote:SNIP Having done a bit more research, I realize I need to do more research, lol! SNIP
Awesome Statement
- Zinc Member
I absolutely love my cold cut "Evolution" brand. much more accurate cuts IMHO. Abrasive disk flex causing crooked cuts many times. Best options: thick stock, horizontal bandsaw. thinner stock and shapes and tubing, cold cut saw.
- 7 Replies
- 651 Views
Last post by HOTT
- 147 Replies
- 17930 Views
Last post by Jsaladin04
- 6 Replies
- 183 Views
Last post by robin1731
- 2 Replies
- 506 Views
Last post by Fred Camper
- 30 Replies
- 5868 Views
Last post by 83gl1200
