New to me bike Rebuild & Restore
- Lead Member
Hello All. My name is Joe and I recently picked up a 1975 Goldwing. It is Candy Blue/Green. It had been sitting for an extended period of time and not running. The previous owner had it outside with the air filter cover off and it appears that water had worked its way down the carbs and into the right cylinders. Probably because the bike was on its side stand and this was the path of least resistance. Pressure was 120 PSI on the Left side and 60 PSI on the right. Anyway, I removed the valve head, cleaned it up, re-seated the valves and got the clearances in spec. There was some corrosion on the cylinder walls but I lightly honed each one with the pistons all the way down. I know that the engine is going to have to be split and redone but I just wanted to get her to fire up. Upon re-assembly I retested the pressure and got 120 PSI out of all cylinders. She fired right up and runs great.
The bike needs a total rebuild. My questions now are; can the cylinder walls be salvaged with light pitting? I have no images to show. And, should I rebuild the whole engine? Or just wait until it needs a full rebuild and just replace the top end gaskets, belts and hoses? Either way, the whole bike is getting a full original rebuild and the engine will be painted.
I am new to all of this and know that I have rambled on in about 50 different directions, so please go easy
1975 Honda Goldwing Gl1000
1978 Honda CB750A Hondamatic (Sold )
1981 Yamaha Xj550 (Maxim) Rebuit
1985 Suzuki GS450L (Completely Restored)
- RIP: cookie
Re: New to me bike Rebuild & Restore
Welcome to the 'Wingdom.
The comp numbers will come up when you run her a bit ...... after you change the timing belts .....
Nice bike Year1Goldwing, mine looked worst than that when I got her.
As RAT said change the timing belts first.
Resurrecting a 1977 GL1000 with 7,380 miles
welcome to NGW.... worse case scenario water rusted out the jugs
- Graham Cracker
Nice ride you've got there...welcome
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- Lead Member
Thanks guys for the responses. The day I picked up the bike was the day I bought new Timing Belts . I will take preventative maintenance any day. I read (probably on here) about the numbers going up as the bike runs.
Should I leave in alone internally and clean up the outside? Or, should I just split the case and start from the first bolt? This is my winter project and have put all other bike work aside. Wishful thinking for this winter,
- RIP: cookie
I would wait until you have assessed how it performs before you plan your re build.
Internal engine parts can be difficult to source ......
- Lead Member
Thanks Gord. I appreciate it. That was my original intent. Get the bike running and take it out and see what I am dealing with. I know that I want to rebuild it either way. Just trying to sort everything out and get some professional advice. Unfortunately to get a good honed cylinder the engine has to be split. Any other bike that I have worked on I was able to remove the cylinders and hone or replace them. This is all knew to me and I appreciate any help that is offered to me.RAT wrote:I would wait until you have assessed how it performs before you plan your re build.
- duke182
Welcome to the club.
Imo, unless the engine is smoking badly or is losing large quantities of oil, I would put it into service and ride it till the wheels fell off.
Like gord said, some enternals can be hard to find, so, why put yourself through it unless you have to.
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- wog
+1 on not splitting it.
These engines are amazingly hardy.
Oh, and nice looking bike
- Lead Member
Oh, and nice looking bike [/quote]
Thanks Guys. I took the whole bike apart this weekend . Everything (But the engine); with the engine I am going to just going the clean up the outside, change the timing belts , clean up the pistons, re-tap the valves and check clearances, and replace all gaskets. Carburetor has already been rebuilt. Going to get the frame painted and start the rebuild process one part at a time by either rebuilding, replacing or re polishing. Hopefully I will be done by next season.
Also, I am probably going to go as original as possible. So the Vetter fairing is coming off along with any other aftermarket parts.
Wish me luck. I will try and post pics as I go.
Should I move this to another forum?
Thanks for everything so far.
- Frame. Pre sand and paint.
- Goldwingframe1.JPG (85.62 KiB) Viewed 1023 times
- redwood
- Forum Greeter
Welcome to NGW! love the color
Redwood
Three amazing Grandsons and a beautiful granddaughter, four great kids, two crazy cats, a husband who is fun to have around and two great motorcycles, one is an 1200 Interstate currently apart being painted and a Harley. (hey, I believe in riding, and everyone should ride what they love. And I happen to have MBS)
- duke182
Way to jump right in.
You will most likely get more responses and views if you start a thread in the "members restoration and projects" forum.
Its listed in the board index.
1984 1200 standard
vote in my poll
1984 1200 standard
vote in my poll
- 52 Replies
- 4660 Views
Last post by Geekdriver
- 142 Replies
- 16587 Views
Last post by Track T 2411
- 75 Replies
- 6953 Views
Last post by robbie202
- 13 Replies
- 760 Views
Last post by Irishman1
- 9 Replies
- 472 Views
Last post by Whiskerfish
