Jama exhaust & centre stand
- Lead Member
Hi
I'm a new member who has just become a proud owner of a 1977 Turquoise GL1000. it's fairly original, and in a fair condition. one of the modifications is a full Jama stainless steel exhaust. as the bike does not have the centre stand fitted, I believe it may be because of this exhaust, can anyone confirm if this is the case?
also my speedo trip knob is missing, can this be replaced or will it require another speedo?
thanks in advance.
Richard
thanks in advance.
Richard
Re: Jama exhaust & centre stand
I have the full Jama Stainless Steel exhaust on my 1979 and still have my center stand.buellxb1200 wrote:Hi
thanks in advance.
Richard
There is a piece that sticks out on the left side that is the bump stop for the center stand.
If you don't have one then previous owner removed for some reason.
See if that V shaped piece has the rubber stop on it if not they may have removed thinking it was hitting something it shouldn't.
1981 HONDA BANDIT CB890CR CAFE RACER
1979 HONDA GL1000 GOLDWING (Naked of course)
2012 KAWASAKI CONCOURS 14
- duke182
Welcome
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- Lead Member
I have just had a look and the bump stop is still on the exhaust, so the previous owner must have removed the centre stand for some reason.. thank you for your help, best get on ebay asap..
1999 Aprilia SR125 Harada rep scooter (very pimped)
2004 650 Suzuki Burgman (totally standard)
1994 Honda VFR 750 (best all rounder in the world)
2003 Buell XB1200S (extremely pimped)
2015 Honda NC700D (a little bit pimped)
2011 BMW K1300R (the evilest bike in the world)
1977 Honda GL1000 (naked with a small oil leak).
Welcome from Aust 6209.... The centre stand as has been said will work... Did you know (trust me here) the PO took up another career after mastering the centre stand and took the stand as a souvenir/reminder....
1975 Goldwing #1 SOLD
- Lead Member
thank you for welcome. I only got the wing yesterday morning, I had it delivered to work and I have not touched it yet, unfortunately I was greeted with a small puddle of oil, which looks like it's from the drain bolt. I used to have the same model way back in 1979 (i know, I don't look old enough..), I cant get over how small it feels. I remember them as being huge. i've started it once and its a bit lumpy, going to get some new plugs and fresh fuel first. is it worth investing in Iridium plugs or just standard NGK's?
Richard
Richard
It would be very wise to give us as much history as you have gathered.. eg , last run, miles it done, recent work, carbs, ignition type meaning points or electronic?... Anything related to the mechanical history.... The brains trust will get on board soon and solve the basics....
Forget the iridium plugs ATM,,, Spend that money on new belts... very essential unless they were changed recently..
You can post pics after you have 5 posts....... Rules everybodys got rules
- Lead Member
I bought it from a dealer, who I asked to change the belts, how do I check they have been done? it says 38000 miles on the clock, I have no history whatsoever. it does start, but as I say is quite lumpy. the fuel is really low, so I have no idea how old it is, hence fresh fuel & new plugs. I'll get the standard NGKD8ES-L's quoted in the Haynes manual I got with it.
It has an MOT and appears in fair condition, I do not want to restore it, I want to use it, getting it running right is my first objective, after that the brakes (new braided hoses), electrics (the horn has a separate switch on the handle bars), then the cosmetics.
Richard
Richard
Now that you have a early GL1000 the next best thing to acquire is a workshop manual... Manuals available in the "Tech talk"thingy????. I bought a Haynes manual and a friend gave me a Clymer manual.... I cant seem to find the HAynes anymore, but i do like the coloured electrics of the Clymer, (photo copied to A3 and laminated) much more info and easily sourced IMO..
You WILL need it sooner than later..
- Lead Member
fortunately I got a Haynes manual with the bike, it has the less taste full easy rider version on the cover.. I'm off to Halfords in a minute to get the new plugs, I'll let you know how it goes...
Richard
Richard
welcome to NGW. I suppose the best way to know if the dealer changed the belts would be if they handed you the old ones when they were done
- Lead Member
well I changed the plugs, the old one's didn't look that old. the right hand (off side) plugs were quite Black & sooty, the near side were not to bad. it would not tick on choke, I wondered if the choke was only working on one side, due to the off side plugs being sooty. the new plugs didn't make a lot of difference to the general running. I put fresh fuel in and rode it home (I had it delivered to work).
Firstly the general running was poor, when I pulled up at junctions the tick over was about 2000 rpm, making me wonder if it had been wound up due to the lack of tick over on choke, trying to pull away was a case of having to rev it up as its very lumpy low down and chugs away, once you get going it seems to be smoother. Secondly the braking, the front brakes just didn't work, back brake wasn't too bad. thirdly the handling, 50 mph produced a gentle weave. I don't think there is any oil in the forks.
This is all fixable, I am concerned about the general running, I think the carbs are going to have to come off and be looked at, I took the battery off when I got home and top it up as it was low, and put it on an Optimate, this morning I had all green lights, however I will get it checked as I seem to remember a low battery can affect the running.
I'll keep you posted..
Richard
Richard
low batteries do not effect running as long as the charging system is working. Now a dead battery will definitely stall an engine as the power goes through the battery and a dead cell will short out the power. Randakk has an excellent carb kit as well as a DVD on how to do them.
- redwood
- Forum Greeter
Welcome to NGW!
Redwood
Three amazing Grandsons and a beautiful granddaughter, four great kids, two crazy cats, a husband who is fun to have around and two great motorcycles, one is an 1200 Interstate currently apart being painted and a Harley. (hey, I believe in riding, and everyone should ride what they love. And I happen to have MBS)
- 3 Replies
- 414 Views
Last post by bottona
- 18 Replies
- 997 Views
Last post by duke182
- 15 Replies
- 1111 Views
Last post by salukispeed
- 14 Replies
- 490 Views
Last post by BiKenG
