First timer
First timer
Just bought myself a 1981 GL1100I with 45k on it. Never embarked on a journey like this before, but I’m pretty mechanical, and looking forward to customizing something. Going through Roady’s Front Engine Renewal Project. Water pump was already replaced, and there was no thermostat. Maybe there was a problem with overheating before? Rebuilt the brake calipers also, and bled the lines. The bore had this thick clay like stuff in the bottoms, and idea what would cause that? And how to I prevent it in the future?
- Sugs
Re: First timer
Welcome. Timing belts are always job one. Nothing can destroy a motor faster than a broken belt. It happens a lot. Do them.
- delling3
Re: First timer
Gray stuff forms when brake fluid gets contaminated with water. One reason to flush your brake fluid as part of regular maintenance.
Welcome to the club. Post some pictures when you can.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
- TNTbefree
Re: First timer
Welcome to the club. Also, Start a build thread with lots of pics. We love it, and so will you, as a record of all that you have done.
Re: First timer
Welcome from Wisconsin. I'm kind of partial to 1100's, myself. It has been my experience that if the bike had cooling issues (like a bad water pump), the p.o. often would try to get around the proper fix by removing the thermostat and/or add a switch to the cooling fan circuit to bypass the thermo switch, or hot wire the fan to run all the time. Fix it right, and you should be good to go! Enjoy the ride!
Re: First timer
welcome aboard.
Put a thermostat in it. An engine will run warmer with no thermostat installed. The coolant needs time in the radiator to pull the heat from it. Removing the thermostat doesn't allow that.
- RIP: cookie
Re: First timer
Welcome to the 'Wingdom.
Lots of good stuff here.
Re: First timer
Definitely doing the timing belts, got the radiator pulled out, and the covers pulled off. Just waiting for the belts to get here on Monday.desertrefugee wrote:Welcome. Timing belts are always job one. Nothing can destroy a motor faster than a broken belt. It happens a lot. Do them.
Re: First timer
I did install a thermostat. I don’t see any switch for the fan, although I suppose it could have been on the fairing. I haven’t ridden it long enough to get the coolant up to temp. Just a quick test ride before I bought it.Track T 2411 wrote:Welcome from Wisconsin. I'm kind of partial to 1100's, myself. It has been my experience that if the bike had cooling issues (like a bad water pump), the p.o. often would try to get around the proper fix by removing the thermostat and/or add a switch to the cooling fan circuit to bypass the thermo switch, or hot wire the fan to run all the time. Fix it right, and you should be good to go! Enjoy the ride!
Re: First timer
Cool. You might want to test the thermo switch while you've got it all apart. They do go bad, and it's easier to get to it now. I don't remember if that's covered in Roady's write-up, or not.Rlind177 wrote:I did install a thermostat. I don’t see any switch for the fan, although I suppose it could have been on the fairing. I haven’t ridden it long enough to get the coolant up to temp. Just a quick test ride before I bought it.Track T 2411 wrote:Welcome from Wisconsin. I'm kind of partial to 1100's, myself. It has been my experience that if the bike had cooling issues (like a bad water pump), the p.o. often would try to get around the proper fix by removing the thermostat and/or add a switch to the cooling fan circuit to bypass the thermo switch, or hot wire the fan to run all the time. Fix it right, and you should be good to go! Enjoy the ride!
Re: First timer
Wondering if anyone knows what this is?
It fell when I was removing the radiator. Can’t tell where it’s supposed to go back. It is threaded inside.
- chewy999
Re: First timer
Not sure, but is it one of the anchor points for one of the bolts holding the radiator in place? What else have you taken off in that area?
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- chewy999
Re: First timer
Just clutching at straws, but has it fallen off item 7 here, https://www.cmsnl.com/honda-gl1100-gold ... vdb2eSG99A
Previous Rides,
Current bikes
Current bikes
- 12 Replies
- 506 Views
Last post by Don R
- 0 Replies
- 1400 Views
Last post by jdog109socal
