new guy from missouri, 77 gl1000.
Moderators: Neil, redwood, rcmatt007, Forum Moderators
just picked this bike up Friday. 18,000 original miles. posted locally and languished online for over a week.
meet the seller at a storage facility and worked out a price fair for both of us.
his father bought the bike in the early eighties from the original owner and rode it occasionally for decades. he quit riding in the nineties and it's stewardship was handed over to his son. had the carbs done, timing belt, tires, etc. and rode a bit before moving on to a new bike.
front brake wooden, rear will slow, not stop the bike. carbs would only perform with choke on, enough to ride it around the parking lot where i got it from to check it out. speedo and tach needles sluggish. tach and speedo lights not working, nor neutral light.
got it home and removed the windshield/rear rack/trunk/driving lights/friction cruise control. wanted it as Soichiro Honda and myself envisioned it.
been messing with it a bit. siphoned the old/new gas out of the tank (minor rust speckling near the bottom), filled it with new stuff and mucked about a bit with the carbs on the bike using this as a guide:
https://www.motorcycleproject.com/text/ ... _bike.html
actually helped quit a bit idles, pulls strong, put a couple of miles on it is all.
getting a little weeping from the water pump. can riding it a bit more help the seals swell back up or is it water pump time?
don't burst my bubble yet. this bike is a solid 9-9.5 cosmetically and i'm still in the honeymoon stage with it.
Re: new guy from missouri, 77 gl1000.
IMG_6611 (1).jpg[/attachment][/img]
period accoutrements removed.
- IMG_6611 (1).jpg (206.75 KiB) Viewed 315 times
overcast, but out in the daylight pre-wash.
- IMG_6619.JPG (243.77 KiB) Viewed 308 times
- IMG_6621.JPG (217.81 KiB) Viewed 308 times
- IMG_6622.JPG (243.24 KiB) Viewed 308 times
- IMG_6625.JPG (223.02 KiB) Viewed 308 times
- IMG_6629.JPG (193.75 KiB) Viewed 308 times
- robbie202
welcome from DC. what a clean bike!
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- ritalz
Yes, very clean. Welcome from St Louis. Perhaps we will see each other on the roads.
- Chainman
Welcome.
Regarding the water pump, I would run it (I'm no expert).
1975 GL1000
Welcome from Wisconsin. The water pump is notorious for failure, especially if the bike sat for a long period of time. That said, unless you're planning any long trips soon, you might get by with keeping a close watch on it. Some here have experienced only occasional leaks from the weep hole... I will add that of the five Wings I've worked on, all have had water pumps replaced. Just sayin'...
- RIP: cookie
Welcome to the 'Wingdom.
Nice find !
Nice find !
had to put a 1977 Missouri plate on it. 007, license to kill.
- IMG_6634.JPG (192.08 KiB) Viewed 273 times
My first was a '77. Same color, designs - loved it. The water pump seal is mechanical. They don't swell up. Some will weap a little from time to time and last long (they are lubricated by the fluid they seal). If they start leaking much, they just get worse. A drop around the tell-tale hole or on the floor under the bike occasionally may actually be a good thing. A puddle, not so much.
good to know. i'll keep an eye on it. as of now its exactly as you describe.
thanks
thanks
Good lord that’s clean, I love it.
Congrats on the new bike, I’m still very much in the honeymoon period with mine too.
1976 GL1000
“America has always been about speed. Hot, nasty, badass speed” -Eleanor Roosevelt
- 15 Replies
- 1305 Views
Last post by bbuice
- 10 Replies
- 898 Views
- 11 Replies
- 561 Views
Last post by maury
