Battle axe -79 GL1000 cafe build
- Zinc Member
Re: Battle axe -79 GL1000 cafe build
It's also for sale now as I picked up my next project. A 2012 Harley dyna fatbob. The hd mufflers I was going to try we're way to long for what I wanted. But the glasspacks from Amazon give it just the right amount of volume, reduce backfiring and gave it more even power through the low end. I can feel it's a little less juice that the h pipes but it's minor. Worth it to cut 30 pounds. I also plan on wrapping the pipes and installing the engine guards as I'm pretty sure that's how the last owner cracked the valve cover.
1979 Honda GL1000 Battle Axe (cafe)
2012 HD fxdf dyna fatbob
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
Tore down the engine guards, sanded them, removed highway pegs. Sanded them down and used vht epoxy paint
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
Highway pegs and engine guards are done. Now I just need the new valve covers and I can put it back together.
- IMG_20180418_211157.jpg (135.82 KiB) Viewed 328 times
- IMG_20180418_211445.jpg (178.28 KiB) Viewed 328 times
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
New uncracked valve covers with a new paint job. Using vht epoxy this time for 250 degrees. For some reason the high heat paint wouldn't cure on the old covers even after baking. So now it will match the timing covers.
- IMG_20180420_214003.jpg (148.22 KiB) Viewed 310 times
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
Well I replaced the valve covers and found a bit of milky oil. And it’s the water pump. So 200 bucks on amazon for a Oem replacement with seals and gaskets. Yeah.
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
Finally got around to removing the headers and wrapping them with fiberglass. Wow that itches. I wore gloves but next time it's long sleeves. Just waiting for the silicone spray to arrive before I reinstall them. I also put the new valve covers on and found some coolant in the oil. Checked the impeller on the water pump. It moves sise to side alot so that was ordered. Tommorow I'm installing the new tach cable as the old one snapped at the top with the new gauge.
- IMG_20180510_001603626_LL.jpg (822.17 KiB) Viewed 264 times
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
I've also decided to add a surfboard rack and dual sport tires. I might as well have fun until I sell it. So I'm waiting on the rear luggage rack. Then I'll order the board rack. And just run with one saddle bag on the other side
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
All the wrap I've used the directions say to soak it in water first before install. That would keep from itching.Crash7 wrote:snip.............Finally got around to removing the headers and wrapping them with fiberglass. Wow that itches.
- Zinc Member
Hmm that may have helped. Ill deffinately try it next time. My directions left that tip out. Just says wrap it and spray with high temp silicone.
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- Zinc Member
The engine guards came out pretty nice. Mufflers and water pump it will be ready to ride.
- IMG_20180510_204255_865.jpg (113.25 KiB) Viewed 233 times
previous
2000 BMW K1200LT
Kawasaki 440 LTD
previous
2000 BMW K1200LT
Kawasaki 440 LTD
- 54 Replies
- 7044 Views
Last post by Old Fogey
- 15 Replies
- 2626 Views
Last post by theburgundian
- 19 Replies
- 4381 Views
Last post by wingrider
- 7 Replies
- 593 Views
