Meet Ol' Sparky
- Lead Member
Re: Meet Ol' Sparky
Excellent thank you for the link.
- HOTT
Re: Meet Ol' Sparky
Good Good! PM sent.jmott wrote:Hey Ric I finally got back on the build.....
I do think I have a bit of frame twist also. After I have the rear suspension done I will build a jig to see if the front and rear are aligned.
Jason
Re: Meet Ol' Sparky
Since the rake was increased (or decreased depending on how you define it) quite a bit, I was surprised that the trail is still about 4". What was it for the original std. GL then?
Ken
You can't have too many bikes
- HOTT
Re: Meet Ol' Sparky
Yes a correction is needed there it is more like 5.5+. I just didn't do it right
I've read some articles that had the '83 as much as 5.3? With a 29 rake?? And 1200's with a 4.5 with a 30 rake ??? Don't know.
thanks
thanks
Re: Meet Ol' Sparky
The ultimate solution might be to rake the frame out less, but then use new yokes (triple clamps) with a larger offset to reduce the trail again. Either that or use 'raked yokes' to angle the forks more and reduce the trail that way. The latter being harder to do, but can be used to greater effect.
Another way would be to use leading axle forks, but off the top of my head I can't think of any that would be suitable for the Wing.
Ken
Re: Meet Ol' Sparky
“Another way would be to use leading axle forks, but off the top of my head I can't think of any that would be suitable for the Wing.”
It works. From a Magna, 2” internal shortened. I believe my trail is close to stock but raked 32 degrees. Zoom in to see the axle placement.
Re: Meet Ol' Sparky
Ah, the Magna 1100. Not imported here and I don’t recall ever seeing one, so I tend to forget them. Good call though, they look really good on your bike Eric. Did you cut and re-weld the top of the frame to change the head angle?ericheath wrote:“Another way would be to use leading axle forks, but off the top of my head I can't think of any that would be suitable for the Wing.”
Ken
Re: Meet Ol' Sparky
Yes, same way HOT did on Ol’ Sparky. 1000’s are slightly different.
I wonder if the Sabre would be a better candidate for a rake with slightly longer forks but axle behind center. I just had the Magna’s on hand.
- 479 Views
Last post by Track T 2411
- 31 Replies
- 3519 Views
Last post by desertrefugee
- 20 Replies
- 3898 Views
Last post by Fred Camper
- 32 Replies
- 10990 Views
Last post by OCR
- 4 Replies
- 1523 Views
Last post by ritalz
