Meet Ol' Sparky
Re: Meet Ol' Sparky
No it handles great going down the road it only wants to flop sitting still ... I think I checked the rake on on it to be around 36 stock I think is 29
1980 GL1100 Interstate naked
1982 GL1100 Interstate Bobber ( in progress )
1983 GL1100 Interstate Bagger
- HOTT
Re: Meet Ol' Sparky
I just gave a look at a pic of your ride. A little more of a full side view would help,Topwingnut wrote:No it handles great going down the road it only wants to flop sitting still ... I think I checked the rake on on it to be around 36 stock I think is 29
but I'm guessin' you would need to drop her an inch. Suggest slightly longer tubes.
It will still look bitchen'
Re: Meet Ol' Sparky
O was kinda hoping for some type of tube extensions ...
Re: Meet Ol' Sparky
Here's a side view Rick ...
- HOTT
Re: Meet Ol' Sparky
thanks,Topwingnut wrote:Here's a side view Rick ...
I went back and reviewed your thread too.
2 things I noticed if I may;
the rear is slightly raised and the head tube
can be dropped more. The rear isn't a deal
breaker, but it amplifies the front end
situation. It's a game of small increments, yes?
Re: Meet Ol' Sparky
Can you explain what your talking about ?? The rear has to be raised otherwise the tire hits the fuel tank .. Head can be dropped more ?? Are you talking about taking it out more ??
- ianstaley
Re: Meet Ol' Sparky
Just out of interest I cant help wondering what the ally cylinder is under the seat, as in the first picture I can see the gas tank just where it is supposed to be. So why the cylinder. Ian
- HOTT
Re: Meet Ol' Sparky
I'll try.Can you explain what your talking about ??
If the rear is where it needs to be, that is where we'll start.
..Because we intended to use a fixed (stock) length fork.
You must lower the head (or steer) tube as you kick the fork out.
The amount you lower increases rapidly for every inch or degree you rake.
i.e. my rake at 32deg. requires less lowering than your 35deg. of rake to keep
the bike level*.
The easy adjustment (IMHO) would be to slide your present forks down in the triple tree
to find ideal ride height. Look for a level or slightly passed level stance to the floor.
Now add the gap distance to the top clamp to your present fork, and you will know
the correct length to order for new tubes.
or... go back and read closely about cut #1 and using the jack to lower the head tube.
*Level also should take into account desired weight distribution. Longer forks may
need the CG a little higher.
Hope this helps.
- HOTT
Re: Meet Ol' Sparky
Ian,ianstaley wrote:Just out of interest I cant help wondering what the ally cylinder is under the seat, as in the first picture I can see the gas tank just where it is supposed to be. So why the cylinder. Ian
The al-U-mini-um tank is a fuel source. I tried to give it the look of an old style
'oil bag'. It shares plumbing with a section of the original fuel tank and is controlled by the
Honda petcock. http://www.ngwclub.com/forum/viewtopic. ... 48#p324948 Total combined capacity, just under 3 gal. US.
Re: Meet Ol' Sparky
You know I just realized something that could make a difference lol... I've got the airline off that goes from one tube to the other ... I don't know if it'll raise it any or just stiffen it ...
Re: Meet Ol' Sparky
As far as raking it an dropping the head tube I did exactly what you did I followed ur directions to the T ... But I did rake mine out further by 5 degrees more than you so I'm sure that makes a difference ... I need sum manifolds that tuck really tight anyone got any ??
- ianstaley
Re: Meet Ol' Sparky
Long distance tank what a great idea. if you don't object I will also do that. Out of interest, as my bike is not registered in the UK I have to get the bike first MOT'd you need this every year after 3 years old as a sort of fit for the road certificate. So I would first have to get the bike on the road mot'd, imported, registered and then re strip and rebuild to make a bobber. I think I have found a better way, I have bought a British frame with all it's documentation, I think you call it a "title" in the states so I will just build that frame as I like so long as it is roadworthy no problem and I don't have to import the old frame.
I got the used frame for a £100 collected. So I will be able to take apart my own frame for future use. Ian
- HOTT
Re: Meet Ol' Sparky
Sorry I thought I had rebuilt all the photos since Photojunkit dropped us all in the grease. I since went back and did some more fill ins....I was wondering if I could ask you a couple of questions about your build of Sparky. I read your post a couple of times. The pictures are gone where you did the rear suspension of the bike.
Wondering if you still had the pictures of what you did to the frame and if you could tell me the shocks you purchased for your build....
FYI, I have plenty of shots of the build. Feel free to drop me a PM or better yet add a post, and let me know if I've missed anything.
thanks
HOTT (see you in Deadwood)
- Lead Member
Re: Meet Ol' Sparky
Hey Ric I finally got back on the build. '78 frame trying to replicate what you built.
Question for you. On the rear end with the boards you have on. Is that still stock height?
I raked out right at 32 degrees. Just trying to figure out how high I should be on the rear.
I do think I have a bit of frame twist also. After I have the rear suspension done I will build a jig to see if the front and rear are aligned.
Jason
Jason
Re: Meet Ol' Sparky
Cheaper than a jig is the string method
https://www.motorcycle.com/how-to/chass ... -3444.html
The diagrams are missing but if you google this title and author you’ll find it .
If you’re out a lot, you may need a jig then.
- 479 Views
Last post by Track T 2411
- 31 Replies
- 3527 Views
Last post by desertrefugee
- 20 Replies
- 3899 Views
Last post by Fred Camper
- 32 Replies
- 11053 Views
Last post by OCR
- 4 Replies
- 1524 Views
Last post by ritalz
