Moderators: sunnbobb , Neil , Forum Moderators
Dirt Road Cowboy
Posts: 128 Joined: Mon Oct 14, 2013 8:51 pm
#331
Post
by Dirt Road Cowboy » Sat Sep 13, 2014 5:53 pm
Superexification wrote: Started life as a 85 wing.
Looks great!
We need details!
VW power?
78 GL1000
DirtRoadCowboy.com
Superexification
Posts: 18 Joined: Sat Sep 13, 2014 1:18 pm
#332
Post
by Superexification » Sat Sep 13, 2014 7:07 pm
Yes.
2110 cc stoker.
"You have to build it before it can be called custom"
Wolfie666
Posts: 131 Joined: Mon Aug 05, 2013 1:45 pm
#333
Post
by Wolfie666 » Mon Sep 22, 2014 6:42 pm
OK, been quite awhile, but although it's not completely complete, I have the old girl running...
2014-09-14 13-05-44.jpg (107.63 KiB) Viewed 220 times
2014-09-14 13-06-02.jpg (97.8 KiB) Viewed 220 times
Don't take life seriously,
You will never get out alive!
Topwingnut
Posts: 309 Joined: Thu Sep 26, 2013 10:47 pm
#334
Post
by Topwingnut » Mon Sep 22, 2014 6:47 pm
Wolfie .. How does she run with the side drafts ? Looks good , very sweet looking ..
1980 GL1100 Interstate naked
1982 GL1100 Interstate Bobber ( in progress )
1983 GL1100 Interstate Bagger
Topwingnut
#335
Post
by Topwingnut » Mon Sep 22, 2014 6:52 pm
Question Super ... When you flipped the transmission over does that not reverse everything ?
Wolfie666
#336
Post
by Wolfie666 » Mon Sep 22, 2014 6:57 pm
Topwingnut, runs great, but very noisy! I removed 2/3 of the baffles and the intake is louder!
Topwingnut
#337
Post
by Topwingnut » Mon Sep 22, 2014 7:03 pm
Mine is just straight pipes an its loud .... The best thing I see you have done is you have opened up a prime location for an alternator ...
Superexification
#338
Post
by Superexification » Mon Sep 22, 2014 7:41 pm
Wolfe 66
Sorta fun to have a weber by each knee huh?
Superexification
#339
Post
by Superexification » Mon Sep 22, 2014 7:45 pm
Topwingnut
Yes upside down does reverse it.
But backwards also reverses it.
It goes the right direction. But still does have some custom machine work done inside.
Yep and loud too. Cold start. No choke. Have to force warm up. Working on fuel injection though.
2110 VW Trike: http://youtu.be/W3_OVNRpOFQ [/youtube]
Superexification on Mon Sep 22, 2014 8:12 pm, edited 3 times in total.
Topwingnut
#340
Post
by Topwingnut » Mon Sep 22, 2014 7:49 pm
Well that's what I'm interested in finding out .., what did you have to do to get it flowing in the correct direction ?
Topwingnut
#341
Post
by Topwingnut » Mon Sep 22, 2014 8:00 pm
After a bit of googling, I've learned that in a VW transaxle you can flip the differential ring gear over to the other side of the input pinion, reversing the final drive's direction.
Superexification
#342
Post
by Superexification » Mon Sep 22, 2014 8:03 pm
Well I guess the u tube link didn't work.
The rotation is correct.
Backward mounting make it the wrong way.
Upside would too.
Both at the same time is reversing the reversing.
So the rotation is correct.
It is an unusual way of doing it though.
The dub ring and pinion is helical NOT hypoid.
The case is symmetrical.
Most normal people just pull the diff and ring out and install it in from the other side. This puts the ring on the other side of the pinion. Simple reverse direction trans.
But....
I wanted low ground clearance like motorcycle. I did not want the normal car clearance. Inverting the box put my engine 6 inches closer to the ground than a normal dub engine would be.
I have a whole 3-1/2 inches under the drain plug.....unloaded.
Superexification
#343
Post
by Superexification » Mon Sep 22, 2014 8:08 pm
So to run it upside down you have to make it oil.
Drill some oil ports, plug off some others.
Drill drain backs.
Topwingnut
#344
Post
by Topwingnut » Mon Sep 22, 2014 8:16 pm
10 - 4 loud an clear ... I understand the concept now ...
Wolfie666
#345
Post
by Wolfie666 » Tue Sep 30, 2014 9:15 pm
oops.
Last post by DustyDingus
Tue Apr 07, 2020 5:19 pm
Last post by Don R
Sun Jul 09, 2017 9:26 pm
Last post by robin1731
Tue Jul 29, 2014 10:06 pm
