polishing aluminum???
55mphx4
Post by 55mphx4 »
I've polished aluminum before, but I'm having issues with removing the almost 40 year old clearcoat that Honda used. Does anyone have any suggestions on what kind (brand) of clearcoat will work the best? Thanks
Re: polishing aluminum???
Most recommend not clear coating after polishing. Just keep up on the polishing.
Dog Boy
Post by Dog Boy »
A lot of the guys here have chemically stripped the clearcoat. I used Rustoleum aircraft stripper and the clearcoat literally fell off under the force of the kitchen faucet. As far as clearcoating after polishing, I believe the general consensus is to not clearcoat the pieces as most of the clearcoats presently available, have a tendency to yellow or chip off due to rock ticks, etc.
I'm confident, someone with more knowledge will be along shortly.
AL
They call me "Dog Boy"
Can't blame the "PO"
Original owner 76 LTD
Team 993
tomk1960
Post by tomk1960 »
Here's an alternative - single stage chrome powder coating that mimics polished aluminum. One coat and it's done. Just keep it clean and never have to worry about oxidation again.
1986 VFR750F Interceptor
1978 Honda GL1000
matalex60
Post by matalex60 »
I recently started using this Jelly. It works incredible. I used to use Aircraft remover, which works well but gets a bit pricey. I apply this jelly for about 10-15min and then leave it on while I wet sand 600,1000,and then 1500.
Matalex
Current Bikes:
1975 GL1000 Bobber
1975 GL1000 Candy Blue Green Restoration
1977 GL1000 Black Restoration
1984 GL1200 Interstate all original
Aircraft stripper is what we use. I have been considering a clear powder coat after polishing, however, I find the aluminum does not seem to corrode that badly if it is wiped up once in a while. A spray clear coat traps moisture underneath, and is not so good, IMHO.
Placerville
Post by Placerville »
sunnbobb wrote: A spray clear coat traps moisture underneath, and is not so good, IMHO.
.....and you won't find any clear coat that will match the quality of the original coating. Like everyone says above.....no clear coat. Just polish it.
Placerville - 1976 Yellow
Survivor - BOTM - May 2011
New and Confused ?
Push the Big Button
55mphx4
Post by 55mphx4 »
I'm kinda liking the powdercoat idea. Will it work for the valve covers? We do have a place locally that I will check with. As far as clearcoat I don't think I will do that. I don't think you could ever clearcoat like Honda did. It's durable to say the least. Thanks for the help!
tomk1960
Post by tomk1960 »
It works fine with valve covers, belt covers, or whatever you don't feel like polishing any more. I do these all the time and they look better than new when they're done.
1978 Honda GL1000
They do look as good as new, but not as nice as Sunnbobb's. It's a matter of preference, looks like powdercoat may win for maintenance. I made a mistake last year, Dec.26th, to take a tool around Winnipeg with my bike. Whatever salt concoctions they use on the roads destroyed my labor of polish. I should have washed it right after I was done.
Missourimike
Post by Missourimike »
"Sharkhide", made for the Navy/Military originally to protect bare metal(SS, brass, alum) in highly corrosive atmospheres. Wipe, spray, a couple coats onto polished surface and it will adhere and protect for years. Re-apply every couple of years. Not a clearcoat, but does the same job without flaking, chipping, discoloring.
'76 Yello Café to be
'83 CX650C Needs Work
'83 CX650C #2 Daily Rider
'79 Yamaha XS750
tomk1960
Post by tomk1960 »
I agree that there's nothing more beautiful than a highly polished piece of aluminum. Sunnbobb does amazing work and it's obvious that he enjoys doing it. I spent many hours polishing a bunch of parts on the first bike I restored years back and everything looked great for the first year, but then the required maintenance started showing it's face. I wouldn't do it again unless it was a restoration that I was trying to make look totally original. There are useful and appropriate applications both both approaches.
Here's a pair of valve covers fresh out of the oven today:
1978 Honda GL1000
55mphx4
Post by 55mphx4 »
wonder if it would be noticeable if I powder coated the front cover and polished the valve covers and intake runners. I may go with jet-hot coating on my exhaust??? I don't have much cash in this bike and it's cheap to insure, so I will probably have this for a long time. That's why I'm looking for reasonably low maintenance.
Nice work tom, I like that alot. Also plus one on the sharkhide.
trail_guy2001
Post by trail_guy2001 »
Great idea for parts that won't make the trip to Sunnbob. Could you mention the powdercoat brand info?
1977 GL1000
