Wog's '78 Wild Child build
wog
Re: Wog's '78 Wild Child build
#646
Post by wog »
Think I'm going in this direction instead. :IDTS:
Should allow me to make them a little bit shorter.
RIP: cookie
#647
Loverly ....
Gord action1
‘76 project .... R2B3 .... sold ...
Team 898, Team LTD 993 ....
My Original 'RAT' was an '82 CB900/1100F
wog
#648
Post by wog »
For anyone still following along...
I got another old machine running again so I can cut the angles correctly (and safely).
Here's were I'm at with the mounting.
With this style, I can keep the carbs aligned left to right instead of having the right side in front because of the engine layout.
After seeing if it all works with the longer intakes, I'll make a cover that mimics the side "gas tank" profile to somewhat hide the intakes...
Plan on forming it from aluminum and probably powder coating it flat black instead of polishing. Also having a cutout in the top center to mimic the valve cover and mainly to keep someone from "adjusting" the carb screws. :IDTS:
Also plan on going with the OEM manifolds for the intakes instead of V-stacks. Cut and re-weld them to plates to match the carbs. Not sure if I'll keep the rubber boots or attach filters directly to the front of the aluminum.
Any input, thoughts, comments is appreciated. anim-cheers1
#649
I'll be curious to see how this all works. You'll get a bit of ram air effect at higher speeds so jetting will probably need to richened up some. The air flow through the manifolds could be interesting. Some pretty abrupt changes in flow there.
1975 GL1000 parts bike (parts for sale)
wog
#650
Post by wog »
ericheath wrote:snip... Subaru runners sweep down and then back up and down again. I’m assuming it’s to help with flow. ...
Just googled that, thanks. This example doesn't come up and back down again but I can imagine what you mean. They keep the curves instead of my 45 degree angles, but seems like a lot of distance.??
I don't mind finishing this with the way I'm heading, but always willing to change it as I go along. Not heading for a high-performance type build. Just wrenching and having fun. :crosso
#651
#652
robin1731 wrote:There was this too. https://www.macsmotorcitygarage.com/sec ... induction/
I've envisioned a cross ram type setup with Weber (or other) side draft carbs to keep a lower profile. Haven't researched it at all, however...
RIP: cookie
#653
You certainly have lots of old, esoteric machines kicking around ....
wog
#654
Post by wog »
Been-a-while update.
Wish there was a easy way to rotate picture attachments via the website.
Mine seem to always be uploaded sideways, but you guys said you like pictures :lol:
wog
#655
Post by wog »
Was going with the V-stacks, and having a rain cover option stored inside the "gas tank". But now leaning towards keeping the ram style cover on permanently. I can just see some nice person pouring a beer down one for kicks or here in FL, a couple lovebugs getting sucked in. Playing around with different styles. The rear will be closed and front having a foam filter with protective screen.
wog
#656
Post by wog »
Latest is 4" diameter alum tube formed with my ironworker (sideways, I gave up rotating :IDTS: )
This way it's a little more oval at the rear.
First picture I went too far with the pressure on the second piece.
Second pic, got it right.
wog
#657
Post by wog »
Cut the two holes, make the front cover, weld the rear plate, and probably install an adjustable damper in the middle to control flow to the rear intake.
Sand and polish with my new to me last year PARTS-FLINGER-12000...
Guaranteed to fling items through my shop wall, to about a half mile away! lolol
(intake on top just for scale)!
txtriathlete
#658
Post by txtriathlete »
Crazy how tall that intake/carb/intake stack is. Put some lights in there and you could do away with the turn signals! :-D
A few of my favorite things...
82 GL1100 Interstate - The PhatGL - Current Project
77 GL1000 - Next on deck - will be converted to a dual sport
99 Vakyrie Interstate - Daily (when the weather is nice) Driver
78 GL1000 Vetter - Restored to original - Sold
79 GL1000 Vetter - Refurbished as a Driver - Sold
78 GL1000 Naked - Project I never got around to - Sold
78 GL1000 "Old Gold" - The one that started me on this crazy path- Sold
95 20th Anniversary 1500 Wing - Sold
99 Kawi Drifter "Faux Indian" - Sold
03 100th Anniversary Harley Heritage Springer Softail - Sold
wog
#659
Post by wog »
txtriathlete wrote:Crazy how tall that intake/carb/intake stack is. Put some lights in there and you could do away with the turn signals! :-D
Cagers and most bikers here don't use turn signals anyway.
anim-cheers1
But almost half the distance of what it was...
#660
I'm liking the oval tube look!
