GL 1200
- salukispeed
Re: GL 1200
That is not a recognized way to bypass the stator plug. (Cut, Clean and solder) works if the stator is good. Other wise the engine would have to come out to replace the stator. Or you could go to a Poor Boy alternator. With some effort Both are good solutions.. Not a bad looking bike for the age. Paint on Mine is more faded than yours.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Miro
Re: GL 1200
Hi salukispeed
This is condition of the bike when purchased; no work was done at this time.
More handy work with electrical marretts;
Re: GL 1200
Gotta love wire nuts on a 12 volt system.
Just another P.O. deal. Hope you can get it done right. I have seen worse, unfortunately.
Re: GL 1200
fortunately 1200 carbs are very easy to work on.... I don't know what is worse, wire nuts and those blue easy splice things
Re: GL 1200
I vote the wire nuts worse. But the blue things are also bad. no doubt a PO that new nothing about wiring
Re: GL 1200
See my other post. I have a set of 1200 carbs if you want to get it running. They're from an 85 I think.
- Miro
- Miro
- Miro
Re: GL 1200
Ericheath,
Thanks for your kind offer, as you can see I’ll give it a try with thorough clean first.
Re: GL 1200
Looks good. The bike looks to be in pretty good shape.
- Miro
Re: GL 1200
Carbs are cleaned and installed back in.
- Floats level adjusted
- Air/fuel mixture adjusted
- Vacuum 9 @ 1000rpm
- Carbs synced
- Carbs synced
Re: GL 1200
You've got an excellent start on it. (New belts yet?)
What's your plan?
What's your plan?
- salukispeed
Re: GL 1200
Nice work on the carbs and sync. so important to the proper running of the bike. Have you plans for the trunk and bags. My 84 is a good solid bike but the sun has destroyed the paint and faded it till the silver shows through. I know shipping is a bummer for large stuff. Might you have a price in mind if you are selling?
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
- 1 Replies
- 165 Views
Last post by Whiskerfish
- 3 Replies
- 284 Views
Last post by Old Fogey
- 580 Views
Last post by Oldewing
